Kincler |
9.10.2009, 15:46
Вот встретил коды неисправностей для OBD-2 на TLC200.
Вполне возможно, что вдали от дилера, но при наличии в сервисе сканера OBD-2 чем то помогут. P00AF Turbocharger/Supercharger Boost Control "A" Module Performance P00B0 Turbocharger/Supercharger Boost Control "B" Module Performance P0046 Turbocharger / Supercharger Boost Control Solenoid Circuit Range / Performance P0047 Turbocharger/Supercharger Boost Control "A" Circuit Low P0048 Turbocharger/Supercharger Boost Control "A" Circuit High P004B Turbocharger/Supercharger Boost Control Solenoid "B" Circuit Range/Performance P004C Turbocharger/Supercharger Boost Control Solenoid "B" Circuit Low P004D Turbocharger/Supercharger Boost Control Solenoid "B" Circuit High P0069 MAP Sensor Too High or Too Low P0087 Fuel Rail / System Pressure - Too Low P0088 Fuel Rail / System Pressure - Too High P0093 Fuel System Leak Detected - Large Leak P0100 Mass or Volume Air Flow Circuit P0101 Mass or Volume Air Flow Circuit Range / Performance Problem P0102 Mass or Volume Air Flow Circuit Low Input P0103 Mass or Volume Air Flow Circuit High Input P0105 Manifold Absolute Pressure / Barometric Pressure Circuit P0106 Manifold Absolute Pressure / Barometric Pressure Circuit Range / Performance Problem P0107 Manifold Absolute Pressure / Barometric Pressure Circuit Low Input P0108 Manifold Absolute Pressure / Barometric Pressure Circuit High Input P0110 Intake Air Temperature Circuit P0112 Intake Air Temperature Circuit Low Input P0113 Intake Air Temperature Circuit High Input P0115 Engine Coolant Temperature Circuit P0116 Engine Coolant Temperature Circuit Range / Performance Problem P0117 Engine Coolant Temperature Circuit Low Input P0118 Engine Coolant Temperature Circuit High Input P0122 Throttle / Pedal Position Sensor / Switch "A" Circuit Low Input P0123 Throttle / Pedal Position Sensor / Switch "A" Circuit High Input P0168 Fuel Temperature Too High P0180 Fuel Temperature Sensor "A" Circuit P0182 Fuel Temperature Sensor "A" Circuit Low Input P0183 Fuel Temperature Sensor "A" Circuit High Input P0190 Fuel Rail Pressure Sensor Circuit P0192 Fuel Rail Pressure Sensor Circuit Low Input P0193 Fuel Rail Pressure Sensor Circuit High Input P0222 Throttle / Pedal Position Sensor / Switch "B" Circuit Low Input P0223 Throttle / Pedal Position Sensor / Switch "B" Circuit High Input P0299 Turbocharger / Supercharger Underboost P0335 Crankshaft Position Sensor "A" Circuit P0339 Crankshaft Position Sensor "A" Circuit Intermittent P0340 Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor) P0400 Exhaust Gas Recirculation Flow P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low P0406 Exhaust Gas Recirculation Sensor "A" Circuit High P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low P0408 Exhaust Gas Recirculation Sensor "B" Circuit High P0488 Exhaust Gas Recirculation Throttle Position Control Range / Performance P0500 Vehicle Speed Sensor "A" P0504 Brake Switch "A" / "B" Correlation P0560 System Voltage P0606 ECM / PCM Processor P0607 Control Module Performance P0617 Starter Relay Circuit High P0627 Fuel Pump Control Circuit / Open P062D Fuel Injector Driver Circuit Performance Bank1 P062E Fuel Injector Driver Circuit Performance Bank2 P1229 Fuel Pump System P1238 Injector Malfunction P1248 Exhaust Gas Recirculation Flow Bank 2 P1251 Turbocharger / Supercharger Overboost Condition (Too High) P1258 VNT Position Sensor Range/Performance Bank 2 Sensor 1 P1259 VNT Position Sensor Low Bank 2 Sensor 1 P1260 VNT Position Sensor High Bank 2 Sensor 1 P1262 VNT Position Sensor Low Bank 2 Sensor 2 P1263 VNT Position Sensor High Bank 2 Sensor 2 P1495 Intake Air Temperature Sensor 1 Circuit P1496 Intake Air Temperature Sensor 1 Circuit Low P1497 Intake Air Temperature Sensor 1 Circuit High P1601 Injector Correction Circuit Malfunction (EEPROM) P1611 IC Circuit Malfunction P2120 Throttle / Pedal Position Sensor / Switch "D" Circuit P2121 Throttle / Pedal Position Sensor / Switch "D" Circuit Range / Performance P2122 Throttle / Pedal Position Sensor / Switch "D" Circuit Low Input P2123 Throttle / Pedal Position Sensor / Switch "D" Circuit High Input P2125 Throttle / Pedal Position Sensor / Switch "E" Circuit P2127 Throttle / Pedal Position Sensor / Switch "E" Circuit Low Input P2128 Throttle / Pedal Position Sensor / Switch "E" Circuit High Input P2138 Throttle / Pedal Position Sensor / Switch "D" / "E" Voltage Correlation P213B Exhaust Gas Recirculation Throttle Position Control (Range / Performance) P2226 Barometric Pressure Circuit P2228 Barometric Pressure Circuit Low Input P2229 Barometric Pressure Circuit High Input P2563 Turbocharger/Supercharger Boost Control Position Sensor "A" Circuit Range/Performance P2564 Turbocharger/Supercharger Boost Control Position Sensor "A" Circuit Low P2565 Turbocharger/Supercharger Boost Control Position Sensor "A" Circuit High P2588 Turbocharger/Supercharger Boost Control Position Sensor "B" Circuit Low P2589 Turbocharger/Supercharger Boost Control Position Sensor "B" Circuit High |
Roma |
9.10.2009, 19:14
Еще общие коды для Toyota
Here are some generic Toyota codes. P1100 BARO Sensor Circuit malfunction P1120 Accelerator Pedal Position Sensor Circuit Malfunction P1121 Accelerator Pedal Position Sensor Range/Performance Problem P1125 Throttle Control Motor Circuit Malfunction P1126 Magnetic Clutch Circuit Malfunction P1127 ETCS Actuator Power Source Circuit Malfunction P1128 Throttle Control Motor Lock Malfunction P1129 Electric Throttle Control System Malfunction P1130 Air-Fuel Sensor Circuit Range/Performance P1133 Air-Fuel Sensor Circuit Response Malfunction P1135 Air-Fuel Sensor Heater Circuit Response Malfunction P1150 A/F Sensor Circuit Range/Performance Malfunction P1153 A./F Sensor Circuit Response Malfunction P1155 A/F Sensor Heater Circuit Malfunction P1200 Fuel Pump Relay Circuit Malfunction P1300 Igniter Circuit Malfunction No. 1 P1305 Igniter Circuit Malfunction No. 2 (1998-2000 Land Cruiser, 2000 Celica & Tundra ) P1310 Igniter Circuit Malfunction No. 2 (Except 1998-2000 Land Cruiser, 2000 Celic & Tundra) P1310 Igniter Circuit Malfunction No. 3 (1998-2000 Land Cruiser, 2000 Celica & Tundra ) P1315 Igniter Circuit Malfunction No. 4 (1998-2000 Land Cruiser, 2000 Celica & Tundra ) P1320 Igniter Circuit Malfunction No. 5 (1998-2000 Land Cruiser & 2000 Tundra ) P1325 Igniter Circuit Malfunction No. 6 (1998-2000 Land Cruiser & 2000 Tundra ) P1330 Igniter Circuit Malfunction No. 7 (1998-2000 Land Cruiser & 2000 Tundra ) P1335 No CKP Sensor Signal Engine Running P1340 Igniter Circuit Malfunction No. 8 (1998-2000 Land Cruiser & 2000 Tundra ) P1346 VVT Sensor /Camshaft Position Sensor Circuit Range/ Performance Problem (Bank 1) P1349 VVT System Malfunction P1400 Sub-Throttle Position Sensor Malfunction P1401 Sub-Throttle Position Sensor Range/Performance Problem P1405 Turbo Pressure Sensor Circuit Malfunction P1406 Turbo Pressure Sensor Range/Performance Problem P1410 EGR Valve Position Sensor Circuit Malfunction P1411 EGR Valve Position Sensor Circuit Ranger/Performance P1500 Starter Signal Circuit Malfunction P1510 Boost Pressure Control Circuit Malfunction P1511 Boost Pressure Low Malfunction P1512 Boost Pressure High Malfunction P1520 Stop Lamp Switch Signal Malfunction P1565 Cruise Control Main Switch Circuit Malfunction P1600 ECM BATT Malfunction P1605 Knock Control CPU Malfunction P1630 Traction Control System Malfunction P1633 ECM Malfunction ECTS Circuit P1645 Body ECU Malfunction P1652 IACV Control Circuit Malfunction P1656 OCV Circuit Malfunction P1658 Waste Gate Valve Control Circuit Malfunction P1661 EGR Circuit Malfunction P1662 EGR By-Pass Valve Control Circuit Malfunction P1690 OCV Circuit Malfunction P1692 OCV Open Malfunction P1693 OCV Closed Malfunction P1780 PNP Switch Malfunction Расшифровка диагностических кодов протокола OBD-II Пятизначный код ошибки Первая позиция: P - is for powertrain codes B - is for body codes C - is for chassis codes Вторая позиция: 0 - общий для OBD-II код 1 - код производителя Третья позиция - тип неисправности: 1 - топливная система или воздухоподача 2 - топливная система или воздухоподача 3 - система зажигания 4 - вспомогательный контроль 5 - холостой ход 6 - ECU или его цепи 7 - трансмиссия 8 - трансмиссия Четвертая и пятая позиции - Порядковый номер ошибки КОД Описание ошибки P0100 Неисправность цепи датчика расхода воздуха P0101 Выход сигнала датчика расхода воздуха из допустимого диапазона P0102 Низкий уровень выходного сигнала датчика расхода воздуха P0103 Высокий уровень выходного сигнала датчика расхода воздуха P0105 Неисправность датчика давления воздуха P0106 Выход сигнала датчика давления воздуха из допустимого диапазона P0107 Низкий уровень выходного сигнала датчика давления воздуха P0108 Высокий уровень выходного сигнала датчика давления воздуха P0110 Неисправность датчика температуры всасываемого воздуха P0111 Выход сигнала датчика температуры всасываемого воздуха из допустимого диапазона P0112 Низкий уровень датчика температуры всасываемого воздуха P0113 Высокий уровень датчика температуры всасываемого воздуха P0115 Неисправность датчика температуры охлаждающей жидкости P0116 Выходсигнала датчика температуры охлаждающей жидкости из допустимого диапазона P0117 Низкий уровень датчика температуры охлаждающей жидкости P0118 Высокий уровень датчика температуры охлаждающей жидкости P0120 Неисправность датчика положения дроссельной заслонки "A" P0121 Выход сигнала датчика положения дроссельной заслонки "A" из допустимого диапазона P0122 Низкий уровень выходного сигнала датчика положения дроссельной заслонки "A" P0123 Высокий уровень выходного сигнала датчика положения дроссельной заслонки "A" P0125 Низкая температура охлаждающей жидкости для управления по замкнутому контуру P0130 Датчик кислорода 1 (банк 1) неисправен P0131 Низкий уровень сигнала датчика кислорода 1 (банк 1) P0132 Высокий уровень сигнала датчика кислорода 1 (банк 1) P0133 Медленный отклик датчика кислорода 1 (банк 1) на обогащение/обеднение P0134 Нет активности выходного сигнала датчика кислорода 1 (банк 1) P0135 Нагреватель датчика кислорода 1 (банк 1) неисправен P0136 Датчик кислорода 2 (банк 1) неисправен P0137 Низкий уровень выходного сигнала датчика кислорода 2 (банк 1) P0138 Высокий уровень выходного сигнала датчика кислорода 2 (банк 1) P0139 Медленный отклик датчика кислорода 2 (банк 1) на обогащение/обеднение P0140 Нет активности выходного сигнала датчика кислорода 2 (банк 1) P0141 Нагреватель датчика кислорода 2 (банк 1) неисправен P0142 Датчик кислорода 3 (банк 1) неисправен P0143 Низкий уровень выходного сигнала датчика кислорода 3 (банк 1) P0144 Высокий уровень выходного сигнала датчика кислорода 3 (банк 1) P0145 Медленный отклик датчика кислорода 3 (банк 1) на обогащение/обеднение P0146 Нет активности выходного сигнала датчика кислорода 3 (банк 1) P0147 Нагреватель датчика кислорода 3 (банк 1) неисправен P0150 Датчик кислорода 1 (банк 2) неисправен P0151 Низкий уровень сигнала датчика кислорода 1 (банк 2) P0152 Высокий уровень сигнала датчика кислорода 1 (банк 2) P0153 Медленный отклик датчика кислорода 1 (банк 2) на обогащение/обеднение P0154 Нет активности выходного сигнала датчика кислорода 1 (банк 2) P0155 Нагреватель датчика кислорода 1 (банк 2) неисправен P0156 Датчик кислорода 2 (банк 2) неисправен P0157 Низкий уровень выходного сигнала датчика кислорода 2 (банк 2) P0158 Высокий уровень выходного сигнала датчика кислорода 2 (банк 2) P0159 Медленный отклик датчика кислорода 2 (банк 2) на обогащение/обеднение P0160 Нет активности выходного сигнала датчика кислорода 2 (банк 2) P0161 Нагреватель датчика кислорода 2 (банк 2) неисправен P0162 Датчик кислорода 3 (банк 2) неисправен P0163 Низкий уровень выходного сигнала датчика кислорода 3 (банк 2) P0164 Высокий уровень выходного сигнала датчика кислорода 3 (банк 2) P0165 Медленный отклик датчика кислорода 3 (банк 2) на обогащение/обеднение P0166 Нет активности выходного сигнала датчика кислорода 3 (банк 2) P0167 Нагреватель датчика кислорода 3 (банк 2) неисправен P0171 Слишком бедная смесь (возможен подсос воздуха) P0172 Слишком богатая смесь P0173 Утечка топлива из топливной системы блока цилиндров №2 P0174 Смесь блока цилиндров №2 слишком бедная P0175 Смесь блока цилиндров №2 слишком богатая P0176 Датчик выброса СНх (Fuel Composition) неисправен P0177 Сигнал датчика СНх (Fuel Composition) вне допустимого диапазона P0178 Низкий уровень сигнала датчика СНх (Fuel Composition) P0179 Высокий уровень сигнала датчика СНх (Fuel Composition) P0180 Неисправность цепи датчика температуры топлива "А" P0181 Сигнал датчика температуры топлива "А" вне допустимого диапазона P0182 Низкий уровень сигнала датчика температуры топлива "А" P0183 Высокий уровень сигнала датчика температуры топлива "А" P0185 Неисправность цепи датчика температуры топлива "В" P0186 Сигнал датчика температуры топлива "В" вне допустимого диапазона P0187 Низкий уровень сигнала датчика температуры топлива "В" P0188 Высокий уровень сигнала датчика температуры топлива "В" P0190 Неисправность цепи датчика давления топлива в топливной рампе P0191 Сигнал датчика давления в топливной рампе вне допустимого диапазона P0192 Низкий сигнал датчика давления топлива в топливной рампе P0193 Высокий сигнал датчика давления топлива в топливной рампе P0194 Перемежающийся сигнал датчика давления топлива в топливной рампе P0195 Неисправность цепи датчика температуры масла в двигателе P0196 Сигнал датчика температуры масла в двигателе вне допустимого диапазона P0197 Низкий сигнал датчика температуры масла в двигателе P0198 Высокий сигнал датчика температуры масла в двигателе P0199 Перемежающийся сигнал датчика температуры масла в двигателе P0200 Неисправность цепи управления форсунками P0201 Неисправность цепи управления форсункой №1 P0202 Неисправность цепи управления форсункой №2 P0203 Неисправность цепи управления форсункой №3 P0204 Неисправность цепи управления форсункой №4 P0205 Неисправность цепи управления форсункой №5 P0206 Неисправность цепи управления форсункой №6 P0207 Неисправность цепи управления форсункой №7 P0208 Неисправность цепи управления форсункой №8 P0209 Неисправность цепи управления форсункой №9 P0210 Неисправность цепи управления форсункой №10 P0211 Неисправность цепи управления форсункой №11 P0212 Неисправность цепи управления форсункой №12 P0213 Неисправность цепи управления форсункой холодного старта №1 P0214 Неисправность цепи управления форсункой холодного старта №2 P0215 Неисправность соленоида выключения двигателя P0216 Неисправность цепи контроля времени впрыска P0217 Перегрев двигателя P0218 Перегрев трансмиссии P0219 Слишком высокие обороты двигателя (Engine Overspeed Condition) P0220 Неисправность датчика положения дроссельной заслонки "B" P0221 Сигнал датчика положения дроссельной заслонки "B" вне допустимого диапазона P0222 Низкий уровень сигнала датчика положения дроссельной заслонки "B" P0223 Высокий уровень сигнала датчика положения дроссельной заслонки "B" P0224 Перемежающийся уровень сигнала датчика положения дроссельной заслонки "B" P0225 Неисправность датчика положения дроссельной заслонки "C" P0226 Сигнал датчика положения дроссельной заслонки вне допустимого диапазона "C" P0227 Низкий уровень сигнала датчика положения дроссельной заслонки "C" P0228 Высокий уровень сигнала датчика положения дроссельной заслонки "C" P0229 Перемежающийся уровень сигнала датчика положения дроссельной заслонки "C" P0230 Неисправность первичной цепи управления бензонасосом (упр. реле бензонасоса) P0231 Постоянный низкий уровень вторичной цепи бензонасоса P0232 Постоянный высокий уровень вторичной цепи бензонасоса P0233 Перемежающийся уровень вторичной цепи бензонасоса P0235 Неисправность цепи датчика давления турбонаддува "A" P0236 Сигнал с датчика турбины "A" вне допустимого диапазона P0237 Низкий уровень сигнала с датчика турбины "A" P0238 Высокий уровень сигнала с датчика турбины "A" P0239 Неисправность цепи датчика давления турбонаддува "B" P0240 Сигнал с датчика турбины "B" вне допустимого диапазона P0241 Низкий уровень сигнала с датчика турбины "B" P0242 Высокий уровень сигнала с датчика турбины "B" P0243 Неисправность соленоида затвора выхлопных газов турбины "A" P0244 Сигнал соленоида затвора выхлопных газов турбины "A" вне доп. диапазона P0245 Соленоид затвора выхлопных газов турбины "A" всегда открыт P0246 Соленоид затвора выхлопных газов турбины "A" всегда закрыт P0247 Неисправность соленоида затвора выхлопных газов турбины "B" P0248 Сигнал соленоида затвора выхлопных газов турбины "B" вне доп. диапазона P0249 Соленоид затвора выхлопных газов турбины "B" всегда открыт P0250 Соленоид затвора выхлопных газов турбины "B" всегда закрыт P0251 Неисправность насоса впрыска турбины"A" P0252 Сигнал насоса впрыска турбины "A" не допустимого диапазона P0253 Низкий уровень сигнала насоса впрыска турбины "A" P0254 Высокий уровень сигнала насоса впрыска турбины "A" P0255 Перемежающийся уровень сигнала насоса впрыска турбины "A" P0256 Неисправность насоса впрыска турбины "B" P0257 Сигнал насоса впрыска турбины "B" вне допустимого диапазона P0258 Низкий уровень сигнала насоса впрыска турбины "B" P0259 Высокий уровень сигнала насоса впрыска турбины "B" P0260 Перемежающийся уровень сигнала насоса впрыска турбины "B" P0261 Форсунка цилиндра №1 - замыкание на землю P0262 Форсунка цилиндра №1 - обрыв или замыкание на +12V P0263 Форсунка цилиндра №1 - неисправность драйвера форсунки P0264 Форсунка цилиндра №2 - замыкание на землю P0265 Форсунка цилиндра №2 - обрыв или замыкание на +12V P0266 Форсунка цилиндра №2 - неисправность драйвера форсунки P0267 Форсунка цилиндра №3 - замыкание на землю P0268 Форсунка цилиндра №3 - обрыв или замыкание на +12V P0269 Форсунка цилиндра №3 - неисправность драйвера форсунки P0270 Форсунка цилиндра №4 - замыкание на землю P0271 Форсунка цилиндра №4 - обрыв или замыкание на +12V P0272 Форсунка цилиндра №4 - неисправность драйвера форсунки P0273 Форсунка цилиндра №5 - замыкание на землю P0274 Форсунка цилиндра №5 - обрыв или замыкание на +12V P0275 Форсунка цилиндра №5 - неисправность драйвера форсунки P0276 Форсунка цилиндра №6 - замыкание на землю P0277 Форсунка цилиндра №6 - обрыв или замыкание на +12V P0278 Форсунка цилиндра №6 - неисправность драйвера форсунки P0279 Форсунка цилиндра №7 - замыкание на землю P0280 Форсунка цилиндра №7 - обрыв или замыкание на +12V P0281 Форсунка цилиндра №7 - неисправность драйвера форсунки P0282 Форсунка цилиндра №8 - замыкание на землю P0283 Форсунка цилиндра №8 - обрыв или замыкание на +12V P0284 Форсунка цилиндра №8 - неисправность драйвера форсунки P0285 Форсунка цилиндра №9 - замыкание на землю P0286 Форсунка цилиндра №9 - обрыв или замыкание на +12V P0287 Форсунка цилиндра №9 - неисправность драйвера форсунки P0288 Форсунка цилиндра №10 - замыкание на землю P0289 Форсунка цилиндра №10 - обрыв или замыкание на +12V P0290 Форсунка цилиндра №10 - неисправность драйвера форсунки P0291 Форсунка цилиндра №11 - замыкание на землю P0292 Форсунка цилиндра №11 - обрыв или замыкание на +12 P0293 Форсунка цилиндра №11 - неисправность драйвера форсунки P0294 Форсунка цилиндра №12 - замыкание на землю P0295 Форсунка цилиндра №12 - обрыв или замыкание на +12V P0296 Форсунка цилиндра №12 - неисправность драйвера форсунки P0300 Обнаружены случайные/множественные пропуски зажигания P0301 Обнаружены пропуски зажигания в цилиндре №1 P0302 Обнаружены пропуски зажигания в цилиндре №2 P0303 Обнаружены пропуски зажигания в цилиндре №3 P0304 Обнаружены пропуски зажигания в цилиндре №4 P0305 Обнаружены пропуски зажигания в цилиндре №5 P0306 Обнаружены пропуски зажигания в цилиндре №6 P0307 Обнаружены пропуски зажигания в цилиндре №7 P0308 Обнаружены пропуски зажигания в цилиндре №8 P0309 Обнаружены пропуски зажигания в цилиндре №9 P0310 Обнаружены пропуски зажигания в цилиндре №10 P0311 Обнаружены пропуски зажигания в цилиндре №11 P0312 Обнаружены пропуски зажигания в цилиндре №12 P0320 Неисправноcть цепи распределителя зажигания P0321 Сигнал распределителя зажигания вне допустимого диапазона P0322 Сигнал распределителя зажигания отсутствует P0323 Сигнал распределителя зажигания перемежающийся P0325 Неисправность цепи датчика детонации №1 P0326 Сигнал датчика детонации №1 вне допустимого диапазона P0327 Низкий уровень сигнала датчика детонации №1 P0328 Высокий уровень сигнала датчика детонации №1 P0329 Перемежающийся уровень сигнала датчика детонации №1 P0330 Неисправность цепи датчика детонации №2 P0331 Сигнал датчика детонации №2 вне допустимого диапазона P0332 Низкий уровень сигнала датчика детонации №2 P0333 Высокий уровень сигнала датчика детонации №2 P0334 Перемежающийся уровень сигнала датчика детонации №2 P0335 Ошибка датчика положения коленвала"A" P0336 Ошибка ДПКВ "A" (пропуск одного зуба) P0337 Низкий уровень или замыкание на массу ДПКВ "A" P0338 Высокий уровень или замыкание на +12V ДПКВ "A" P0339 Перемежающийся сигнал ДПКВ "A" P0340 Неисправность датчика распределительного вала P0341 Сигнал датчика распределительного вала вне допустимого диапазона P0342 Низкий уровень сигнала датчика распределительного вала P0343 Высокий уровень сигнала датчика распределительного вала P0344 Перемежающийся уровень сигнала датчика распределительного вала P0350 Неисправность первичной / вторичной цепи катушки зажигания P0351 Неисправность первичной / вторичной цепи катушки зажигания "A" P0352 Неисправность первичной / вторичной цепи катушки зажигания "B" P0353 Неисправность первичной / вторичной цепи катушки зажигания "C" P0354 Неисправность первичной / вторичной цепи катушки зажигания "D" P0355 Неисправность первичной / вторичной цепи катушки зажигания "E" P0356 Неисправность первичной / вторичной цепи катушки зажигания" F" P0357 Неисправность первичной / вторичной цепи катушки зажигания "G" P0358 Неисправность первичной / вторичной цепи катушки зажигания "H" P0359 Неисправность первичной / вторичной цепи катушки зажигания "I" P0360 Неисправность первичной / вторичной цепи катушки зажигания "J" P0361 Неисправность первичной / вторичной цепи катушки зажигания "K" P0362 Неисправность первичной / вторичной цепи катушки зажигания "L" P0370 Неисправность сигнала А таймера P0371 Число импульсов сигнала А таймера выше нормы P0372 Число импульсов сигнала А таймера ниже нормы P0373 Нестабильные импульсы сигнала А таймера P0374 Нет импульсов сигнала А таймера P0375 Неисправность сигнала B таймера P0376 Число импульсов сигнала B таймера выше нормы P0377 Число импульсов сигнала B таймера ниже нормы P0378 Нестабильные импульсы сигнала B таймера P0379 Нет импульсов сигнала А таймера P0380 Неисправность свечи накаливания или цепи нагрева P0381 Неисправность свечи накаливания или индикатора нагрева P0385 Неисправность цепи датчика положения коленвала "B" P0386 Сигнал датчика положения коленвала "B" вне допустимого диапазона P0387 Низкий уровень или замыкание на массу ДПКВ "В" P0388 Высокий уровень или замыкаение на +12V ДПКВ "В" P0389 Перемежающийся сигнал датчика положения коленвала "B" P0400 Неисправность системы рециркуляции отработанных газов P0401 Неэффективность системы рециркуляции отработанных газов P0402 Избыточность системы рециркуляции отработанных газов (ОГ) P0403 Неисправность цепи датчика системы рециркуляции отработанных газов P0404 Сигнал датчика системы рециркуляции ОГ вне допустимого диапазона P0405 Низкий уровень сигнала датчика "A" системы рециркуляции ОГ P0406 Высокий уровень сигнала датчика "A" системы рециркуляции ОГ P0407 Низкий уровень сигнала датчика "В" системы рециркуляции ОГ P0408 Высокий уровень сигнала датчика "В" системы рециркуляции ОГ P0410 Неисправность системы вторичной подачи воздуха P0411 Некорректный поток через систему вторичной подачи воздуха P0412 Неисправность клапана системы вторичной подачи воздуха"A" P0413 Клапан системы вторичной подачи воздуха "A" всегда открыт P0414 Клапан системы вторичной подачи воздуха "A" всегда закрыт P0415 Неисправность клапана системы вторичной подачи воздуха "В" P0416 Клапан системы вторичной подачи воздуха "В" всегда открыт P0417 Клапан системы вторичной подачи воздуха "В" всегда закрыт P0420 Эффективность системы катализаторов В1 ниже допустимого порога P0421 Эффективность прогрева катализаторов В1 ниже допустимого порога P0422 Эффективность главного катализатора В1 ниже допустимого порога P0423 Эффективность нагревателя катализатора В1 ниже допустимого порога P0424 Температура нагревателя катализатора В1 ниже допустимого порога P0430 Эффективность системы катализаторов В2 ниже допустимого порога P0431 Эффективность прогрева катализаторов В3 ниже допустимого порога P0432 Эффективность главного катализатора В2 ниже допустимого порога P0433 Эффективность нагревателя катализатора В2 ниже допустимого порога P0434 Температура нагревателя катализатора В2 ниже допустимого порога P0440 Неисправность контроля системы улавливания паров бензина P0441 Плохая продувка системы улавливания паров бензина P0442 Небольшая утечка в системе улавливания паров бензина P0443 Неисправность цепи клапана продувки системы улавливания паров бензина P0444 Клапан продувки системы улавливания паров бензина всегда открыт P0445 Клапан продувки системы улавливания паров бензина всегда закрыт P0446 Неисправность упр. воздушным клапаном системы улавливания паров P0447 Воздушный клапан системы улавливания паров всегда открыт P0448 Воздушный клапан системы улавливания паров всегда закрыт P0450 Неисправность датчика давления паров бензина P0451 Сигнал датчика давления паров бензина вне допустимого диапазона P0452 Низкий уровень сигнал датчика давления паров бензина P0453 Высокий уровень сигнал датчика давления паров бензина P0454 Перемежающийся уровень сигнал датчика давления паров бензина P0455 Большая утечка в системе улавливания паров бензина P0460 Неисправность цепи датчика уровня топлива P0461 Сигнал датчика уровня топлива вне допустимого диапазона P0462 Низкий уровень сигнала датчика уровня топлива P0463 Высокий уровень сигнала датчика уровня топлива P0464 Перемежающийся уровень сигнала датчика уровня топлива P0465 Неисправность цепи датчика потока воздуха продувки P0466 Сигнал датчика потока воздуха продувки вне допустимого диапазона P0467 Низкий уровень сигнала датчика потока воздуха продувки P0468 Высокий уровень сигнала датчика потока воздуха продувки P0469 Перемежающийся уровень сигнала датчика потока воздуха продувки P0470 Неисправность датчика давления выхлопных газов P0471 Сигнал датчика давления выхлопных газов вне допустимого диапазона P0472 Низкий уровень сигнала датчика давления выхлопных газов P0473 Высокий уровень сигнала датчика давления выхлопных газов P0474 Перемежающийся уровень сигнала датчика давления выхлопных газов P0475 Неисправность клапана датчика давления выхлопных газов P0476 Сигнал клапана датчика давления выхлопных газов вне допустимого диапазона P0477 Низкий уровень сигнала клапана датчика давления выхлопных газов P0478 Высокий уровень сигнала клапана датчика давления выхлопных газов P0479 Перемежающийся уровень сигнала клапана датчика давления выхлопных газов P0480 Неисправность цепи управления реле вентилятора P0500 Нет сигнала датчика скорости автомобиля P0501 Сигнал датчика скорости автомобиля вне допустимого диапазона P0502 Низкий уровень сигнала датчика скорости автомобиля P0503 Высокий уровень сигнала датчика скорости автомобиля P0505 Неисправность регулятора холостого хода P0506 Неисправность регулятора холостого хода - низкие обороты P0507 Неисправность регулятора холостого хода - высокие обороты P0510 Неисправность концевика дроссельной заслонки P0520 Неисправность в цепи датчика давления масла P0521 Неправильный показатель/не отрегулирован датчик давления масла P0522 Низкое напряжение датчика давления масла P0523 Высокое напряжение датчика давления масла P0530 Неисправность в цепи датчика давления охлаждающей жидкости кондиционера P0531 Неправильный показатель/не отрегулирован датчик давления охлаждающей жидкости кондиционера P0532 Низкий показатель датчика давления охлаждающей жидкости кондиционера P0533 Высокий показатель датчика давления охлаждающей жидкости кондиционера P0534 Утечка охлаждающей жидкости кондиционера P0550 Неисправность в цепи датчика давления в гидроусилителе руля P0551 Неправильный показатель/не отрегулирован датчик давления в гидроусилителе руля P0552 Низкий показатель датчика давления в гидроусилителе руля P0553 Высокий показатель датчика давления в гидроусилителе руля P0554 Неисправность датчика давления в гидроусилителе руля P0560 Напряжение питания системы ниже порога работоспособности P0561 Напряжение питания системы нестабильное P0562 Низкое напряжение питания системы P0563 Высокое напряжение питания системы P0565 Неисправность сигнала включения системы круиз-контроля P0566 Неисправность сигнала выключения системы круиз-контроля P0567 Неисправность сигнала продолжения движения системы круиз-контроля P0568 Неисправность сигнала установки скорости системы круиз-контроля P0569 Неисправность сигнала торможения системы круиз-контроля P0570 Неисправность сигнала ускорения системы круиз-контроля P0571 CНеисправность в цепи переключателя торможения A системы круиз-контроля P0572 Низкий показатель переключателя торможения A системы круиз-контроля P0573 Высокий показатель переключателя торможения A системы круиз-контроля P0574 Неисправность системы круиз-контроля P0575 Неисправность системы круиз-контроля P0576 Неисправность системы круиз-контроля P0577 Неисправность системы круиз-контроля P0578 Неисправность системы круиз-контроля P0579 Неисправность системы круиз-контроля P0580 Неисправность системы круиз-контроля P0600 Неисправность при связи с системой P0601 Ошибка контрольной суммы ПЗУ P0602 Программная ошибка блока управления P0603 Ошибка внешнего ОЗУ P0604 Ошибка внутреннего ОЗУ P0605 Ошибка в памяти (ROM) блока управления P0606 Неисправность процессора PCM P0607 Неисправность канала детонации P0608 Неисправность датчика VSS "A" блока управления P0609 Неисправность датчика VSS "В" блока управления P0620 Неисправность в цепи управления генератора P0621 Неисправность в цепи лампы "L" генератора P0622 Неисправность в блоке "F" генератора P0650 Неисправность в цепи индикаторной лампы неисправностей (MIL) P0654 Неправильно отрегулированы обороты двигателя P0655 Неисправность в цепи лампы прогрева двигателя P0656 Неисправность в цепи датчика уровня топлива P0700 Неисправность системы контроля трансмиссии P0701 Система контроля трансмиссии вне допустимого диапазона P0702 Электрическая система контроля трансмиссии P0703 Неисправность в цепи датчика B уменьшения крутящего момента при торможении P0704 Неисправность в цепи датчика сцепления P0705 Неисправность в цепи датчика трансмиссии (PRNDL) P0706 Неправильный показатель / не отрегулирован датчик трансмиссии P0707 Низкий показатель датчика трансмиссии P0708 Высокий показатель датчика трансмиссии P0709 Неисправность датчика трансмиссии P0710 Неисправность в цепи датчика температуры трансмиссионной жидкости P0711 Неправильный показатель / не отрегулирован датчик температуры трансмиссионной жидкости P0712 Низкий показатель датчика температуры трансмиссионной жидкости P0713 Высокий показатель датчика температуры трансмиссионной жидкости P0714 Неисправность датчика температуры трансмиссионной жидкости P0715 Неисправность в цепи датчика оборотов турбины P0716 Неправильный показатель / не отрегулирован датчик оборотов турбины P0717 Нет сигнала от датчика оборотов турбины P0718 Неисправность датчика оборотов турбины P0719 Низкий показатель цепи датчика B уменьшения крутящего момента при торможении P0720 Неисправность в цепи датчика частоты вращения вала P0721 Неправильный показатель / не отрегулирован датчик частоты вращения вала P0722 Нет сигнала от датчика частоты вращения вала P0723 Неисправность датчика частоты вращения вала P0724 Высокий показатель цепи датчика B уменьшения крутящего момента при торможении P0725 Неисправность в цепи датчика оборотов двигателя P0726 Неправильный показатель / не отрегулирован датчик оборотов двигателя P0727 Нет сигнала от датчика оборотов двигателя P0728 Неисправность датчика оборотов двигателя P0730 Неправильно отрегулирована коробка передач P0731 Неправильно отрегулирована 1 передача P0732 Неправильно отрегулирована 2 передача P0733 Неправильно отрегулирована 3 передача P0734 Неправильно отрегулирована 4 передача P0735 Неправильно отрегулирована 5 передача P0736 Неправильно отрегулирована задняя передача P0740 Неисправность в цепи муфты сцепления P0741 Неправильно отрегулирована муфта сцепления P0742 Повреждена муфта сцепления P0743 Повреждение электрической цепи муфты сцепления P0744 Неисправность в цепи муфты сцепления P0745 Неисправность в цепи соленоида давления P0746 Неправильно отрегулирован соленоид давления P0747 Поврежден соленоид давления P0748 Повреждение электрической цепи соленоида давления P0749 Неисправность соленоида давления P0750 Неисправность переключателя А соленоида P0751 Неправильно отрегулирован переключатель А соленоида P0752 Повреждение переключателя А соленоида P0753 Повреждение электрической цепи переключателя А соленоида P0754 Неисправность переключателя А соленоида P0755 Неисправность переключателя B соленоида P0756 Неправильно отрегулирован переключатель B соленоида P0757 Повреждение переключателя B соленоида P0758 Повреждение электрической цепи переключателя B соленоида P0759 Неисправность переключателя B соленоида P0760 Неисправность переключателя C соленоида P0761 Неправильно отрегулирован переключатель C соленоида P0762 Повреждение переключателя C соленоида P0763 Повреждение электрической цепи переключателя C соленоида P0764 Неисправность переключателя C соленоида P0765 Неисправность переключателя D соленоида P0766 Неправильно отрегулирован переключатель D соленоида P0767 Повреждение переключателя D соленоида P0768 Повреждение электрической цепи переключателя D соленоида P0769 Неисправность переключателя D соленоида P0770 Неисправность переключателя E соленоида P0771 Неправильно отрегулирован переключатель E соленоида P0772 Повреждение переключателя E соленоида P0773 Повреждение электрической цепи переключателя E соленоида P0774 Неисправность переключателя E соленоида P0780 Неисправность переключателя P0781 Неисправность 1-2 переключателей P0782 Неисправность 2-3 переключателей P0783 Неисправность 3-4 переключателей P0784 Неисправность 4-5 переключателей P0785 Неисправность соленоида P0786 Неправильный показатель / не отрегулирован соленоид P0787 Низкий показатель датчика соленоида P0788 Высокий показатель датчика соленоида P0789 Неисправность соленоида P0790 Неисправность в цепи переключателя в режим normal P0801 Неисправность в цепи контроля системы Reverse Inhibit P0803 Неисправность в цепи соленоида переключателя 1-4 P0804 Неисправность в цепи контрольной лампы переключателя 1-4 Коды устанавливаемые производителям. Зависят от марки авто. P1000 OBD II Monitor не проходит тест P1001 Key On Engine Running (KOER) Self-Test not able to complete. KOER aborted P1100 Mass Air Flow (MAF) sensor intermittent P1101 Mass Air Flow (MAF) sensor out of Self-Test range P1102 Низкое сопротивление подогревателя датчика кислорода Р1106 Высокое напряжение в цепи датчика абсолютного давления впускного коллектора (MAP) Р1107 Низкое напряжение в цепи датчика абсолютного давления впускного коллектора (MAP) P1110 Switch over valve solenoid P1111 Высокое напряжение в цепи датчика температуры воздуха на впуске (IAT) P1112 Switch over valve 1 Низкое напряжение в цепи датчика температуры воздуха на впуске (IAT) P1113 Switch over valve 2 P1114 Низкое напряжение в цепи датчика температуры охлаждающей жидкости (ECT) P1115 Высокое напряжение в цепи датчика температуры охлаждающей жидкости (ECT) P1116 О2 Sensor heater Circuit (Open) Датчик температуры двигателя (ECT) не прошел самотестирование P1117 Датчик температуры двигателя (ECT) sensor intermittent P1120 Датчик положения дросселя (TP) out of range low P1121 Высокое напряжение в цепи датчика положения дроссельной заслонки (TP) P1122 Низкое напряжение в цепи датчика положения дроссельной заслонки (TP) P1123 Long Term Fuel Trim Additive Air (System too Rich) P1124 Датчик положения дросселя (TP) sensor out of Self -Test range Long Term Fuel Trim Additive Air (System too Lean) P1125 Датчик положения дросселя (TP) sensor circuit intermittent P1127 Exhaust not warm enough, downstream Heated Oxygen Sensors (HO2Ss) not tested Long Term Fuel Trim Multiplicative (System too Rich) P1128 Upstream Heated Oxygen Sensors (HO2Ss) swapped from bank to bank Long Term Fuel Trim Multiplicative (System too Lean) P1129 Downstream Heated Oxygen Sensors (HO2Ss) swapped from bank to bank P1130 Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, adaptive fuel at limit (Bank # 1) P1131 Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, sensor indicates lean (Bank # 1)) P1132 Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, sensor indicates rich (Bank # 1) P1133 Датчик 1 HO2S P1134 Таймер включения датчика HO2S P1136 Long Term Fuel Trim Additive Fuel (System too Rich) P1137 Lack of downstream Heated Oxygen Sensor (HO2S 12) switch, sensor indicates lean (Bank # 1) Long Term Fuel Trim Additive Fuel (System too Lean) P1138 Lack of downstream Heated Oxygen Sensor (HO2S 12) switch, sensor indicates rich (Bank # 1) P1140 Неверный сигнал нагрузки P1150 Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, adaptive fuel at limit (Bank #2) P1151 Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, sensor indicates lean (Bank # 2) P1152 Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, sensor indicates rich (Bank # 2) P1157 Lack of downstream Heated Oxygen Sensor (HO2S 22) switch, sensor indicates lean (Bank # 2) P1158 Lack of downstream Heated Oxygen Sensor (HO2S 22) switch, sensor indicates rich (Bank # 2) P1171 Низкий уровень сигнала СО-потенциометра P1172 Высокий уровень сигнала СО-потенциометра P1174 02 Sensor 1 Bank 1 (period monitoring) P1176 02 Sensor 1 Bank 1 (tv monitoring) P1200 Цепь управления форсункой P1220 Series Throttle Control system malfunction P1224 Датчик положения дросселя B (TP-B) out of Self - Test range P1229 Power Supply Relay Primary Circuit Voltage High P1230 Power Supply Relay Secondary Circuit Voltage Low P1231 Fuel pump relay circuit low with high speed pump on P1232 Low speed Fuel Pump primary circuit malfunction P1233 Fuel Pump Driver Module disabled or offline P1234 Fuel Pump Driver Module disabled or offline P1235 Fuel Pump control out of Self - Test range P1236 Fuel Pump control out of Self - Test range Не считывается показатель датчика положения коленвала (CKP) P1237 Fuel Pump secondary circuit malfunction P1238 Fuel Pump secondary circuit malfunction P1260 Попытка угона - запуск заблокирован P1270 Engine RPM or vehicle speed limiter reached P1285 Неисправность датчика температуры ГБЦ P1288 Датчик температуры ГБЦ (CHT) sensor out of Self - Test range P1289 Датчик температуры ГБЦ (CHT) sensor circuit low input P1290 Датчик температуры ГБЦ (CHT) sensor circuit high input P1299 Engine over temperature condition P1326 Knock Control Maximum Spark Limit Cylinder 1 P1327 Knock Control Maximum Spark Limit Cylinder 2 P1328 Knock Control Maximum Spark Limit Cylinder 3 P1329 Knock Control Maximum Spark Limit Cylinder 4 P1350 Запасная линия мониторинга P1351 Ignition Diagnostic Monitor (IDM) circuit input malfunction P1356 PIPS occurred while IDM pulse width indicates engine not turning P1357 Ignition Diagnostic Monitor (IDM) pulse width not defined P1358 Ignition Diagnostic Monitor (IDM) signal out of Self - Test range P1359 Spark output circuit malfunction P1361 Низкое напряжение в цепи контроля зажигания (IC) P1374 Изменение частоты датчика положения коленвала (CKP) P1380 Неисправность в системе – невозможно считать данные P1386 Knock control Testpulse P1390 Octane Adjust (OCT ADJ) out of Self - Test range P1400 Differential Pressure Feedback EGR (DPFE) sensor circuit low voltage detected P1401 Differential Pressure Feedback EGR (DPFE) sensor circuit high voltage detected P1405 Differential Pressure Feedback EGR (DPFE) sensor upstream hose off or plugged P1406 Differential Pressure Feedback EGR (DPFE) sensor downstream hose off or plugged Регулировка датчика системы рециркуляции выхлопных газов (EGR) P1408 Exhaust Gas Recirculation (EGR) flow out of Self - Test range P1409 Canister purge valve power stage (malfunction) Electronic Vacuum Regulator (EVR) control circuit malfunction P1410 Canister purge valve power stage (high) Secondary air pump relay P1411 Secondary Air Injection system incorrect downstream flow detected P1413 Secondary Air Injection system monitor circuit low voltage P1414 Secondary Air Injection system monitor circuit high voltage P1425 Canister purge valve power stage (low) Цепь управления клапаном продувки адсорбера, замыкание на землю P1426 Цепь управления клапаном продувки адсорбера, обрыв P1441 Расход в системе отвода паров топлива (EVAP) только для автомобиля Chevrolet Расход в системе отвода паров топлива (EVAP) только для автомобиля Oldsmobile P1442 Evaporative emission control system small leak detected P1443 Evaporative emission control system - vacuum system, purge control solenoid or vapor management valve malfunction P1444 Purge Flow (PF) Sensor circuit low input P1445 Purge Flow (PF) Sensor circuit high input P1449 Evaporative emission control system unable to hold vacuum (Probe) P1450 Unable to bleed up fuel tank vacuum P1452 Unable to bleed up fuel tank vacuum P1455 Evaporative emission control system control leak detected (gross leak) P1460 Wide Open Throttle Air Conditioning Cutoff (WAC) circuit malfunction P1461 Air Conditioning Pressure (ACP) sensor circuit low input P1462 Air Conditioning Pressure (ACP) sensor circuit high input P1463 Air Conditioning Pressure (ACP) sensor insufficient pressure change P1464 Air Condition (A/C) demand out of Self - Test range P1469 Low air conditioning cycling period P1473 Fan secondary high with fan(s) off P1474 Low Fan Control primary circuit malfunction P1479 High Fan Control primary circuit malfunction P1480 Fan secondary low with low fan on P1481 Fan secondary low with high fan on P1483 Power to fan circuit over current P1484 Open power ground to Variable Load Control Module (VLCM) P1500 Неисправность цепи реле топливного насоса P1501 Иммобилайзер - нет кода или неправильный код Реле топливного насоса - замыкание на землю P1502 Реле топливного насоса - замыкание на +12V Иммобилайзер - нет сигнала P1503 Иммобилайзер - неправильный сигнал P1504 Idle Air Control (IAC) circuit malfunction P1505 Idle Air Control (IAC) system at adaptive clip P1506 Idle Air Control (IAC) overspeed error P1507 Idle Air Control (IAC) under speed error P1509 Цепь управления регулятором холостого хода, перегрузка P1512 Intake Manifold Runner Control (IMRC) malfunction (Bank # 1 stuck closed) P1513 Intake Manifold Runner Control (IMRC) malfunction (Bank # 2 stuck closed) Цепь управления регулятором холостого хода - замыкание на землю P1514 Цепь управления регулятором холостого хода - обрыв P1516 Intake Manifold Runner Control (IMRC) input error (Bank # 1) P1517 Intake Manifold Runner Control (IMRC) input error (Bank # 2) P1518 Intake Manifold Runner Control (IMRC) malfunction (stuck open) P1519 Intake Manifold Runner Control (IMRC) malfunction (stuck closed) P1520 Intake Manifold Runner Control (IMRC) circuit malfunction P1530 Air Condition (A / C) clutch circuit malfunction P1537 Intake Manifold Runner Control (IMRC) malfunction (Bank # 1 stuck open) P1538 Intake Manifold Runner Control (IMRC) malfunction (Bank # 2 stuck open) P1539 Power to Air condition (A / C) clutch circuit overcurrent P1541 Цепь управления реле бензонасоса, обрыв P1550 Power steering Pressure (PSP) sensor out of Self - Test range P1554 Цепь обратной связи с системой круиз-контроля P1570 Обрыв цепи иммобилизатора P1600 Нет связи с иммобилизатором Reprogram or Replace Electronic Control Unit (ECM) P1601 ECM Box Temperature High P1602 Пропадание напряжения контроллера Модуль контроля детонации P1603 Ошибка EEPROM P1604 Устройство контроля детонации P1605 Устройство контроля детонации P1606 Устройство контроля детонации P1612 Ошибка сброса процессора P1619 Electrical Thermostat Control powerstage (too high) P1620 Ошибка ПЗУ Electrical Thermostat Control powerstage (too low) P1621 Ошибка OЗУ P1622 Ошибка EEPROM Electrical Thermostat Control powerstage (Range/Perfomance) P1625 B(+) supply to ariable Load Control Module (VCLM) fan circuit malfunction P1626 B(+) supply to Variable Load Control Module (VCLM) Air Condition (A / C) circuit malfunction Потеря сигнала от топливной системы P1629 Не поступает сигнал от топливной системы P1635 Цепь 5 вольт, только для автомобиля Oldsmobile Цепь 5 вольт, только для автомобиля Chevrolet P1639 2 цепь 5 вольт, только для автомобиля Oldsmobile 2 цепь 5 вольт, только для автомобиля Chevrolet P1640 Устройство контроля детонации или модуль полного привода P1641 Контрольная цепь индикаторной лампы неисправностей (MIL) P1650 Power Steering Pressure (PSP) switch out of Self - Test range P1651 Power Steering Pressure (PSP) switch input malfunction Контрольная цепь 1 реле вентилятора, только для автомобиля Oldsmobile Контрольная цепь 1 реле вентилятора, только для автомобиля Chevrolet P1652 Контрольная цепь 2 реле вентилятора, только для автомобиля Oldsmobile Контрольная цепь 2 реле вентилятора, только для автомобиля Chevrolet P1654 Контрольная цепь реле кондиционера (A/C) P1655 Контрольная цепь соленоида системы отвода паров топлива (EVAP), только для автомобиля Oldsmobile Контрольная цепь соленоида системы отвода паров топлива (EVAP), только для автомобиля Chevrolet P1662 Цепь системы круиз-контроля P1663 Контрольная лампа перезарядки P1671 Контрольная лампа замены масла P1672 Контрольная лампа низкого уровня масла P1675 Контрольная цепь соленоида системы отвода паров топлива (EVAP) P1689 Ошибка памяти ошибок P1690 Ошибка лампы диагностики MIL-on requestsignal (Malfunction) P1693 MIL-on requestsignal (High) P1701 Reverse engagement error P1703 Brake On/Off (BOO) switch out of Self - Test range P1705 Transmission Range (TR) Sensor out of Self - Test range P1709 Park or Neutral Position (PNP) switch is not indicating neutral during KOEO Self - Test P1711 Transmission Fluid Temperature (TFT) sensor out of Self - Test range P1728 Transmission slip fault P1729 4x4 Low switch error P1740 Torque Control unit P1741 Torque Converter Clutch (TCC) control error P1742 Torque Converter Clutch (TCC) solenoid failed on (turns on MIL) P1743 Torque Converter Clutch (TCC) solenoid failed on (turns on TCIL) P1744 Torque Converter Clutch (TCC) system mechanically stuck in off position P1746 Electronic Pressure Control (EPC) solenoid open circuit (low input) P1747 Electronic Pressure Control (EPC) solenoid short circuit (high input) P1749 Electronic Pressure Control (EPC) solenoid failed low P1751 Shift Solenoid # 1 (SS1) performance P1754 Coast Clutch Solenoid (CCS) circuit malfunction P1756 Shift Solenoid # 2 (SS2) performance P1761 Shift Solenoid # 3 (SS3) performance P1780 Transmission Control switch (TCS) circuit out of Self - Test range P1781 4x4 Low switch out of Self - Test range P1783 Transmission over temperature condition P1788 3-2 Timing / Coast Clutch Solenoid (3-2 / CCS) circuit open P1789 3-2 Timing / Coast Clutch Solenoid (3-2 / CCS) circuit shorted U1021 SCP indicating the lack of Air Condition (A/C) clutch status response U1039 SCP indicating the vehicle speed signal missing or incorrect U1051 SCP indicating the brake switch signal missing or incorrect U1073 SCP indicating the lack of engine coolant fan status response U1131 SCP indicating the lack of Fuel Pump status response U1135 SCP indicating the ignition switch signal missing or incorrect U1256 SCP indicating a communications error U1451 Lack of response from Passive Anti-Theft system (PATS) module - engine disabled Список наиболее употребительных сокращений по OBD II AFC – Расходомер воздуха ALDL – Диагностический коннектор. Так раньше назывался диагностический коннектор для автомобилей GM, а также разъем для подключения сканнера; также может использоваться как название любых сигналов OBD II CAN - Контроллер CARB – Калифорнийский совет по атмосферным ресурсам CFI – центральный впрыск топлива (TBI) CFI – непрерывный впрыск топлива CO – монооксид углерода DLC – Диагностический коннектор Driving Cycle – Последовательность пуска, прогрева и движения автомобиля, в ходе этого цикла происходит тестирование всех функций OBD II DTC – Код неисправности ECM – Блок управления двигателем EEC – Электронное управление двигателем EEPROM or E2PROM – Программируемая память, доступная только для чтения EFI – электронный впрыск топлива EGR - рециркуляция выхлопных газов EMR – электронный блок уменьшения угла зажигания EPA – Совет по охране окружающей среды ESC – Электронная регулировка зажигания EST – Электронная регулировка момента зажигания Fuel Trim – балансировка состава смеси HC - углеводород HEI - зажигание HO2S – подогрев датчика кислорода ISO 9141 – международный стандарт для разъема OBD II J1850PWM – протокол для разъема OBD II, установленный по стандарту SAE J1850VPW - протокол для разъема OBD II, установленный по стандарту SAE J1962 – стандарт для диагностического коннектора OBD II, установленный по стандарту SAE J1978 – стандарт SAE для сканнеров OBD II J1979 – стандарт SAE для режимов диагностики J2012 – стандарт SAE, одобренный EPA, для сообщений при тестировании системы выхлопных газов MAF – расход воздуха MAP – абсолютное давление во впускном коллекторе MAT – температура воздуха во впускном коллекторе MIL – индикаторная лампа неисправностей. Лампа "Check Engine Light" на панели приборов. NOx – оксид азота O2 - кислород OBD - диагностика OBD II or OBD II – усовершенствованный стандарт для диагностики автомобилей в США после 1-1-96 Parameters – Параметры по диагностике OBD II PCM – Блок управления трансмиссией PCV - Картер Proprietary Readings – Параметры бортового компьютера, которые не требуются для диагностики OBD II, но могут использоваться для диагностики неисправностей различных типов автомобилей. PTC – Код неисправности RPM – об/мин Scan Tool - сканнер SES – лампа сервисного обслуживания двигателя на панели приборов SFI – последовательный впрыск топлива Stoichiometric ( Stoy'-kee-o-metric) Ratio – Коэффициент сгорания топлива TPS – Датчик положения дроссельной заслонки VAC - вакуум VCM – центральный блок управления автомобиля VIN – идентификационный номер автомобиля VSS – датчик скорости WOT – открытая дроссельная заслонка |
Lotsman |
25.2.2011, 10:10
Ошибка C168B как расшифровать?
И вот еще B15D8. Сообщение отредактировал Lotsman - 25.2.2011, 12:01 |
Roma |
28.2.2011, 13:24
Цитата Ошибка C168B как расшифровать? точную распечатку не дали, но сказали что это по CAN линии проблема... скорее всего сигнал не доходитЦитата И вот еще B15D8 а эта конкретно отсоединён штеккер в самой "голове", может контакт слабый или окислился.В общем начни с головного монитора... а так надо все контакты проверять |
Lotsman |
1.3.2011, 17:05
А еще В15С2 это что такое?
Roma |
2.3.2011, 12:07
Lotsman |
2.3.2011, 13:48
Roma |
18.5.2011, 7:57
Надписи и сокращения
А ampere(s) - ампер ABS - антиблокировочная система тормозов А/С (air conditioner) - воздушный кондиционер АСС - положение замка зажигания (включен стеклоочиститель, радио, прикуриватель) АСС (accessary) - добавочное питание ACCEL (accelerator) - педаль газа ACL (air cleaner) - воздухоочиститель ADJ ADJUST - регулировка A/F (air fuel ratio) - состав топливновоздушной смеси AIR FLOW METER - датчик расхода воздуха ALB - антиблокировочная система ALT (alternator) - генератор ALT (altitude) - высота AM 1 - питание первой группы контактов замка зажигания AM 2 - питание второй группы контактов замка зажигания АМР - см. А ANT (antenna) - антенна APS - режим перемотки "автопоиск паузы" в магнитофоне ASM (assembly) - сборка А/Т - автоматическая трансмиссия ATDC - после верхней мертвой точки ATF (automatic transmission fluid) - жидкость для автоматической трансмиссии ALTO (automatic) - автоматический В (battery) - батарея BACK UP - задний ход BAND - диапазон (у радиоприемника) BARO (barometric pressure) - атмосферное давление ВАТ - см. В BEAM - дальний свет BELT - ремень BLOWER MOTOR - мотор отопителя салона (он же кондиционера) BOOST - величина вакуума во впускном коллекторе BRAKE - тормоз BREAKER - тепловой размыкатель (предохранитель многократного действия) BTDS - до верхней мертвой точки С см. CONTROL САС (charge air coder) охладитель всасываемого воздуха CAM CAMSHAFT распределительный вал СС кубический сантиметр CDS FAN (condenser fan motor) мотор вентилятора, охлаждение конденсора (радиатора кондиционера) CHECK проверка CHECK CONNECTOR проверочный разъем CHG CHARGE зарядка CHOKE воздушная заслонка CI центральный впрыск CIG FUSE предохранитель прикуривателя СКР (crankshaft position) положение коленчатого вала СМН (cold mixture heater) нагреватель топливной смеси СМР (camshaft position) положение распредвала СО (carbon monoxide) окись углерода COLD холод CONTROL управление CRANK (crankshaft) коленчатый вал D DRIVE движение DEF (defogger) размораживатель , подогрев заднего (переднего) стекла DI (distributor ignition) распределить зажигания DITRIBUTOR трамблер DOHC (double overhead camshaft) двойной распредвал в головке блока DOME панель приборов, салон DOOR CONTROL управление дверью DOWN вниз DTS (diagnostic trouble code) коды самодиагностики DTM (diagnostic tast mode) режим диагностики E END конец (топлива) Е EARTH "земля" (корпус) EAI подача воздуха в выпускную систему ЕВСМ (electronic brake control module) электронный блок управления тормозами ЕСС ( emission control computer) блок управления выбросами (испарениями) двигателя ECI электронный центральный впрыск (тоже CI) ЕСМ (engine control module) см. ECV ECON ECONOMY экономичный (режим работы) ЕСТ (electronic control transmission) электронное учравление трансмиссией ЕСТ (engine coolant temperature) температура двигателя ECU (electric control unit) электрический блок управления EFI электронный впрыск топлива EGR (exhaust gas i ^circulation) возврат выхлопных газов ENG ENGINE двигатель EPS электронное управление амортизаторами EST S см. ЕСТ EVAP (evaporative) система отсоса паров (из бензобака) F (front) перед F (full) полный (уровень топлива) F (или FF). FORWARD вперед FAST быстро FAN MOTOR мотор вентилятора FAN I/UP RELAY реле повышения оборотов холостого хода при включении вентилятора FC (FCUT) FUEL CUT отсечка топлива FL (fusible link) предохранительная вставка FLUID жидкость FOG LIGHTS противотуманные фары FP см. FUEL PAMP FREE свободно FUEL топливо FUEL PAMP топливный насос FUSE предохранитель FUSIBLE LINK предохранительная линия FWD (front wheel drive) передний привод GAUGE датчик GLOG PLUG свеча накаливания Н (hard) жестко (режим подвески) Н (hocr) час Н или Hi (high) высокие (обороты), высокая (передача, температура) НАС (high altitude compensation) система компенсации атмосферного давления HAI (hot air system) система подачи горячего воздуха во впускной коллектор (при работе двигателя на сильном морозе) HAZ (hazard) аварийная сигнализация HEAD LN левая фара HEAD RH правая фара HEAD RH LWR правая фара ближнего света HEAD RH UPR правая фара дальнего света HORN сигнал НОТ горячий HTR (heater) нагреватель IAC (idle air control) управление воздухом в режиме холостого хода IDL (idle) холостой ход IDL/UP см. I/UP IG (IGN) igniter коммутатор IG (IGN) ignition зажигание IGNITION COIL катушка зажигания НА ignition integral assemble интегральная сборка зажигания INJECTOR инжектор INT interval интервал I/UP idle up увеличение оборотов холостого хода L (low) низкие (обороты), низкая (передача, температура) L (left) левое (зеркало, положение) LEVEL уровень LF (left front) левый передний LH (left hand) левая рука LO см. L LOCK блокировка LR (left rear) левый задний LS (left side) левый боковой М (medium) середина М (memory) память М (minute) минута М см. MANU MAP (mass air flow) измеритель объема воздуха MAIN RELAY главное реле MAN см. MANU MANU ручное (управление, регулировка) МС (mixture control) управление составом смеси MIL (malfunction indicator lamp) лампа неисправности ("check") MIRROR зеркало заднего вида MODE выбор режима MPI многоточечный впрыск М/Т механическая трансмиссия N neutral нейтральное (положение) N normal нормальное (состояние) 0/D over drive повышенная передача 2 WAY 0/D автоматическое отключение повышенной передачи ОНС (overhead camshaft) распредвал в головке блока цилиндров OFF выключено OIL масло ON включено OX SENSOR датчик кислорода Р PARKING стоянка РСВ (POWER CB) power control block силовой блок управления (обычно блок управления дверьми, стеклами) PCV (positive crancase ventilation) система вентиляции картера PPS (progressive power steering) система управления усилия на руле PRE HEATING TIMER реле времени предварительного нагрева (обычно свечей накаливания) PUMP насос PULL потянуть PUSH нажать PWR (power) мощностной режим QUICK быстро R (return) возвращение, назад R (right) правое (зеркало, положение) RDI FAN (radiator fan motor) мотор вентилятора радиатора охлаждения двигателя REAR DOOR задняя дверь REAR WASHER MOTOR мотор заднего отмывателя стекла REAR WINDOW DEFOGGER обогреватель заднего стекла RELAY реле RESET установка REV (reversal) изменение направления RICH богатая (смесь) R.P.M. обороты в минуту RR REAR задний (например, RRDEF задний размораживатель) RTR MOTOR retract motor мотор открытиязакрытия фар S (soft) мягкий SAE (Society of Automotive Engineers) общество автомобильных инженеров SEAT HTR seat heater подогрев сидений SEEK поиск SELECT выбор (режима) SENSOR датчик SET установка SLOW медленно SOHC (singl overhead camshaft) один распредвал в головке блока SPD SPEED скорость SPORT (S) спортивный (режим) ST STARTER стартер SUN ROOF люк в крыше автомобиля S/W (switch) выключатель TAIL габаритные (огни) ТВ (throttle body) блок дроссельной заслонки TEMS (Toyota electronic modolated suspension) см. EPS TDS (top dead center) верхняя мертвая точка TEMP (temperature) температура THROTTLE POSITION SENSOR датчик положения дроссельной заслонки THA temperature heat air температура воздуха TGH температура выхлопных газов THW temperature heat water температура воды ("Тосола") TRN TURN поворот TURN RELAY реле поворотов UP вверх VACUUM SENSOR датчик вакуума VALVE клапан VSV (vacum solenoid valve) электромагнитный клапан на вакуумной магистрали WARMER нагреватель W (warning) предупреждение WASHER омыватель WATER вода WD (wheel drive) ведущие колеса WIPER стеклоочиститель WINDOW стекло WS (wheel steer) управляемые колеса 4WD (four wheel drive) полный привод 4А/Т четырехскоростная автоматическая коробка передач |
| Текстовая версия | Сейчас: 1.11.2026, 15:38 |
