> Коды ошибок, TLC200
Kincler
сообщение 9.10.2009, 15:46
Из: Собянинск-Нерезиновск
Пользователь №: 3555
Вот встретил коды неисправностей для OBD-2 на TLC200.
Вполне возможно, что вдали от дилера, но при наличии в сервисе сканера OBD-2 чем то помогут.
P00AF Turbocharger/Supercharger Boost Control "A" Module Performance
P00B0 Turbocharger/Supercharger Boost Control "B" Module Performance
P0046 Turbocharger / Supercharger Boost Control Solenoid Circuit Range / Performance
P0047 Turbocharger/Supercharger Boost Control "A" Circuit Low
P0048 Turbocharger/Supercharger Boost Control "A" Circuit High
P004B Turbocharger/Supercharger Boost Control Solenoid "B" Circuit Range/Performance
P004C Turbocharger/Supercharger Boost Control Solenoid "B" Circuit Low
P004D Turbocharger/Supercharger Boost Control Solenoid "B" Circuit High
P0069 MAP Sensor Too High or Too Low
P0087 Fuel Rail / System Pressure - Too Low
P0088 Fuel Rail / System Pressure - Too High
P0093 Fuel System Leak Detected - Large Leak
P0100 Mass or Volume Air Flow Circuit
P0101 Mass or Volume Air Flow Circuit Range / Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0105 Manifold Absolute Pressure / Barometric Pressure Circuit
P0106 Manifold Absolute Pressure / Barometric Pressure Circuit Range / Performance Problem
P0107 Manifold Absolute Pressure / Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure / Barometric Pressure Circuit High Input
P0110 Intake Air Temperature Circuit
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0115 Engine Coolant Temperature Circuit
P0116 Engine Coolant Temperature Circuit Range / Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0122 Throttle / Pedal Position Sensor / Switch "A" Circuit Low Input
P0123 Throttle / Pedal Position Sensor / Switch "A" Circuit High Input
P0168 Fuel Temperature Too High
P0180 Fuel Temperature Sensor "A" Circuit
P0182 Fuel Temperature Sensor "A" Circuit Low Input
P0183 Fuel Temperature Sensor "A" Circuit High Input
P0190 Fuel Rail Pressure Sensor Circuit
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0222 Throttle / Pedal Position Sensor / Switch "B" Circuit Low Input
P0223 Throttle / Pedal Position Sensor / Switch "B" Circuit High Input
P0299 Turbocharger / Supercharger Underboost
P0335 Crankshaft Position Sensor "A" Circuit
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor)
P0400 Exhaust Gas Recirculation Flow
P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
P0406 Exhaust Gas Recirculation Sensor "A" Circuit High
P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low
P0408 Exhaust Gas Recirculation Sensor "B" Circuit High
P0488 Exhaust Gas Recirculation Throttle Position Control Range / Performance
P0500 Vehicle Speed Sensor "A"
P0504 Brake Switch "A" / "B" Correlation
P0560 System Voltage
P0606 ECM / PCM Processor
P0607 Control Module Performance
P0617 Starter Relay Circuit High
P0627 Fuel Pump Control Circuit / Open
P062D Fuel Injector Driver Circuit Performance Bank1
P062E Fuel Injector Driver Circuit Performance Bank2
P1229 Fuel Pump System
P1238 Injector Malfunction
P1248 Exhaust Gas Recirculation Flow Bank 2
P1251 Turbocharger / Supercharger Overboost Condition (Too High)
P1258 VNT Position Sensor Range/Performance Bank 2 Sensor 1
P1259 VNT Position Sensor Low Bank 2 Sensor 1
P1260 VNT Position Sensor High Bank 2 Sensor 1
P1262 VNT Position Sensor Low Bank 2 Sensor 2
P1263 VNT Position Sensor High Bank 2 Sensor 2
P1495 Intake Air Temperature Sensor 1 Circuit
P1496 Intake Air Temperature Sensor 1 Circuit Low
P1497 Intake Air Temperature Sensor 1 Circuit High
P1601 Injector Correction Circuit Malfunction (EEPROM)
P1611 IC Circuit Malfunction
P2120 Throttle / Pedal Position Sensor / Switch "D" Circuit
P2121 Throttle / Pedal Position Sensor / Switch "D" Circuit Range / Performance
P2122 Throttle / Pedal Position Sensor / Switch "D" Circuit Low Input
P2123 Throttle / Pedal Position Sensor / Switch "D" Circuit High Input
P2125 Throttle / Pedal Position Sensor / Switch "E" Circuit
P2127 Throttle / Pedal Position Sensor / Switch "E" Circuit Low Input
P2128 Throttle / Pedal Position Sensor / Switch "E" Circuit High Input
P2138 Throttle / Pedal Position Sensor / Switch "D" / "E" Voltage Correlation
P213B Exhaust Gas Recirculation Throttle Position Control (Range / Performance)
P2226 Barometric Pressure Circuit
P2228 Barometric Pressure Circuit Low Input
P2229 Barometric Pressure Circuit High Input
P2563 Turbocharger/Supercharger Boost Control Position Sensor "A" Circuit Range/Performance
P2564 Turbocharger/Supercharger Boost Control Position Sensor "A" Circuit Low
P2565
Turbocharger/Supercharger Boost Control Position Sensor "A" Circuit High
P2588 Turbocharger/Supercharger Boost Control Position Sensor "B" Circuit Low
P2589 Turbocharger/Supercharger Boost Control Position Sensor "B" Circuit High
сообщение 9.10.2009, 19:14
Еще общие коды для Toyota
Here are some generic Toyota codes.
P1100 BARO Sensor Circuit malfunction
P1120 Accelerator Pedal Position Sensor Circuit Malfunction
P1121 Accelerator Pedal Position Sensor Range/Performance Problem
P1125 Throttle Control Motor Circuit Malfunction
P1126 Magnetic Clutch Circuit Malfunction
P1127 ETCS Actuator Power Source Circuit Malfunction
P1128 Throttle Control Motor Lock Malfunction
P1129 Electric Throttle Control System Malfunction
P1130 Air-Fuel Sensor Circuit Range/Performance
P1133 Air-Fuel Sensor Circuit Response Malfunction
P1135 Air-Fuel Sensor Heater Circuit Response Malfunction
P1150 A/F Sensor Circuit Range/Performance Malfunction
P1153 A./F Sensor Circuit Response Malfunction
P1155 A/F Sensor Heater Circuit Malfunction
P1200 Fuel Pump Relay Circuit Malfunction
P1300 Igniter Circuit Malfunction No. 1
P1305 Igniter Circuit Malfunction No. 2 (1998-2000 Land Cruiser, 2000 Celica & Tundra )
P1310 Igniter Circuit Malfunction No. 2 (Except 1998-2000 Land Cruiser, 2000 Celic & Tundra)
P1310 Igniter Circuit Malfunction No. 3 (1998-2000 Land Cruiser, 2000 Celica & Tundra )
P1315 Igniter Circuit Malfunction No. 4 (1998-2000 Land Cruiser, 2000 Celica & Tundra )
P1320 Igniter Circuit Malfunction No. 5 (1998-2000 Land Cruiser & 2000 Tundra )
P1325 Igniter Circuit Malfunction No. 6 (1998-2000 Land Cruiser & 2000 Tundra )
P1330 Igniter Circuit Malfunction No. 7 (1998-2000 Land Cruiser & 2000 Tundra )
P1335 No CKP Sensor Signal Engine Running
P1340 Igniter Circuit Malfunction No. 8 (1998-2000 Land Cruiser & 2000 Tundra )
P1346 VVT Sensor /Camshaft Position Sensor Circuit Range/ Performance Problem (Bank 1)
P1349 VVT System Malfunction
P1400 Sub-Throttle Position Sensor Malfunction
P1401 Sub-Throttle Position Sensor Range/Performance Problem
P1405 Turbo Pressure Sensor Circuit Malfunction
P1406 Turbo Pressure Sensor Range/Performance Problem
P1410 EGR Valve Position Sensor Circuit Malfunction
P1411 EGR Valve Position Sensor Circuit Ranger/Performance
P1500 Starter Signal Circuit Malfunction
P1510 Boost Pressure Control Circuit Malfunction
P1511 Boost Pressure Low Malfunction
P1512 Boost Pressure High Malfunction
P1520 Stop Lamp Switch Signal Malfunction
P1565 Cruise Control Main Switch Circuit Malfunction
P1600 ECM BATT Malfunction
P1605 Knock Control CPU Malfunction
P1630 Traction Control System Malfunction
P1633 ECM Malfunction ECTS Circuit
P1645 Body ECU Malfunction
P1652 IACV Control Circuit Malfunction
P1656 OCV Circuit Malfunction
P1658 Waste Gate Valve Control Circuit Malfunction
P1661 EGR Circuit Malfunction
P1662 EGR By-Pass Valve Control Circuit Malfunction
P1690 OCV Circuit Malfunction
P1692 OCV Open Malfunction
P1693 OCV Closed Malfunction
P1780 PNP Switch Malfunction
Расшифровка диагностических кодов
протокола OBD-II
Пятизначный код ошибки
Первая позиция:
P - is for powertrain codes
B - is for body codes
C - is for chassis codes
Вторая позиция:
0 - общий для OBD-II код
1 - код производителя
Третья позиция - тип неисправности:
1 - топливная система или воздухоподача
2 - топливная система или воздухоподача
3 - система зажигания
4 - вспомогательный контроль
5 - холостой ход
6 - ECU или его цепи
7 - трансмиссия
8 - трансмиссия
Четвертая и пятая позиции - Порядковый номер ошибки
КОД
Описание ошибки
P0100
Неисправность цепи датчика расхода воздуха
P0101
Выход сигнала датчика расхода воздуха из допустимого диапазона
P0102
Низкий уровень выходного сигнала датчика расхода воздуха
P0103
Высокий уровень выходного сигнала датчика расхода воздуха
P0105
Неисправность датчика давления воздуха
P0106
Выход сигнала датчика давления воздуха из допустимого диапазона
P0107
Низкий уровень выходного сигнала датчика давления воздуха
P0108
Высокий уровень выходного сигнала датчика давления воздуха
P0110
Неисправность датчика температуры всасываемого воздуха
P0111
Выход сигнала датчика температуры всасываемого воздуха из допустимого диапазона
P0112
Низкий уровень датчика температуры всасываемого воздуха
P0113
Высокий уровень датчика температуры всасываемого воздуха
P0115
Неисправность датчика температуры охлаждающей жидкости
P0116
Выходсигнала датчика температуры охлаждающей жидкости из допустимого диапазона
P0117
Низкий уровень датчика температуры охлаждающей жидкости
P0118
Высокий уровень датчика температуры охлаждающей жидкости
P0120
Неисправность датчика положения дроссельной заслонки "A"
P0121
Выход сигнала датчика положения дроссельной заслонки "A" из допустимого диапазона
P0122
Низкий уровень выходного сигнала датчика положения дроссельной заслонки "A"
P0123
Высокий уровень выходного сигнала датчика положения дроссельной заслонки "A"
P0125
Низкая температура охлаждающей жидкости для управления по замкнутому контуру
P0130
Датчик кислорода 1 (банк 1) неисправен
P0131
Низкий уровень сигнала датчика кислорода 1 (банк 1)
P0132
Высокий уровень сигнала датчика кислорода 1 (банк 1)
P0133
Медленный отклик датчика кислорода 1 (банк 1) на обогащение/обеднение
P0134
Нет активности выходного сигнала датчика кислорода 1 (банк 1)
P0135
Нагреватель датчика кислорода 1 (банк 1) неисправен
P0136
Датчик кислорода 2 (банк 1) неисправен
P0137
Низкий уровень выходного сигнала датчика кислорода 2 (банк 1)
P0138
Высокий уровень выходного сигнала датчика кислорода 2 (банк 1)
P0139
Медленный отклик датчика кислорода 2 (банк 1) на обогащение/обеднение
P0140
Нет активности выходного сигнала датчика кислорода 2 (банк 1)
P0141
Нагреватель датчика кислорода 2 (банк 1) неисправен
P0142
Датчик кислорода 3 (банк 1) неисправен
P0143
Низкий уровень выходного сигнала датчика кислорода 3 (банк 1)
P0144
Высокий уровень выходного сигнала датчика кислорода 3 (банк 1)
P0145
Медленный отклик датчика кислорода 3 (банк 1) на обогащение/обеднение
P0146
Нет активности выходного сигнала датчика кислорода 3 (банк 1)
P0147
Нагреватель датчика кислорода 3 (банк 1) неисправен
P0150
Датчик кислорода 1 (банк 2) неисправен
P0151
Низкий уровень сигнала датчика кислорода 1 (банк 2)
P0152
Высокий уровень сигнала датчика кислорода 1 (банк 2)
P0153
Медленный отклик датчика кислорода 1 (банк 2) на обогащение/обеднение
P0154
Нет активности выходного сигнала датчика кислорода 1 (банк 2)
P0155
Нагреватель датчика кислорода 1 (банк 2) неисправен
P0156
Датчик кислорода 2 (банк 2) неисправен
P0157
Низкий уровень выходного сигнала датчика кислорода 2 (банк 2)
P0158
Высокий уровень выходного сигнала датчика кислорода 2 (банк 2)
P0159
Медленный отклик датчика кислорода 2 (банк 2) на обогащение/обеднение
P0160
Нет активности выходного сигнала датчика кислорода 2 (банк 2)
P0161
Нагреватель датчика кислорода 2 (банк 2) неисправен
P0162
Датчик кислорода 3 (банк 2) неисправен
P0163
Низкий уровень выходного сигнала датчика кислорода 3 (банк 2)
P0164
Высокий уровень выходного сигнала датчика кислорода 3 (банк 2)
P0165
Медленный отклик датчика кислорода 3 (банк 2) на обогащение/обеднение
P0166
Нет активности выходного сигнала датчика кислорода 3 (банк 2)
P0167
Нагреватель датчика кислорода 3 (банк 2) неисправен
P0171
Слишком бедная смесь (возможен подсос воздуха)
P0172
Слишком богатая смесь
P0173
Утечка топлива из топливной системы блока цилиндров №2
P0174
Смесь блока цилиндров №2 слишком бедная
P0175
Смесь блока цилиндров №2 слишком богатая
P0176
Датчик выброса СНх (Fuel Composition) неисправен
P0177
Сигнал датчика СНх (Fuel Composition) вне допустимого диапазона
P0178
Низкий уровень сигнала датчика СНх (Fuel Composition)
P0179
Высокий уровень сигнала датчика СНх (Fuel Composition)
P0180
Неисправность цепи датчика температуры топлива "А"
P0181
Сигнал датчика температуры топлива "А" вне допустимого диапазона
P0182
Низкий уровень сигнала датчика температуры топлива "А"
P0183
Высокий уровень сигнала датчика температуры топлива "А"
P0185
Неисправность цепи датчика температуры топлива "В"
P0186
Сигнал датчика температуры топлива "В" вне допустимого диапазона
P0187
Низкий уровень сигнала датчика температуры топлива "В"
P0188
Высокий уровень сигнала датчика температуры топлива "В"
P0190
Неисправность цепи датчика давления топлива в топливной рампе
P0191
Сигнал датчика давления в топливной рампе вне допустимого диапазона
P0192
Низкий сигнал датчика давления топлива в топливной рампе
P0193
Высокий сигнал датчика давления топлива в топливной рампе
P0194
Перемежающийся сигнал датчика давления топлива в топливной рампе
P0195
Неисправность цепи датчика температуры масла в двигателе
P0196
Сигнал датчика температуры масла в двигателе вне допустимого диапазона
P0197
Низкий сигнал датчика температуры масла в двигателе
P0198
Высокий сигнал датчика температуры масла в двигателе
P0199
Перемежающийся сигнал датчика температуры масла в двигателе
P0200
Неисправность цепи управления форсунками
P0201
Неисправность цепи управления форсункой №1
P0202
Неисправность цепи управления форсункой №2
P0203
Неисправность цепи управления форсункой №3
P0204
Неисправность цепи управления форсункой №4
P0205
Неисправность цепи управления форсункой №5
P0206
Неисправность цепи управления форсункой №6
P0207
Неисправность цепи управления форсункой №7
P0208
Неисправность цепи управления форсункой №8
P0209
Неисправность цепи управления форсункой №9
P0210
Неисправность цепи управления форсункой №10
P0211
Неисправность цепи управления форсункой №11
P0212
Неисправность цепи управления форсункой №12
P0213
Неисправность цепи управления форсункой холодного старта №1
P0214
Неисправность цепи управления форсункой холодного старта №2
P0215
Неисправность соленоида выключения двигателя
P0216
Неисправность цепи контроля времени впрыска
P0217
Перегрев двигателя
P0218
Перегрев трансмиссии
P0219
Слишком высокие обороты двигателя (Engine Overspeed Condition)
P0220
Неисправность датчика положения дроссельной заслонки "B"
P0221
Сигнал датчика положения дроссельной заслонки "B" вне допустимого диапазона
P0222
Низкий уровень сигнала датчика положения дроссельной заслонки "B"
P0223
Высокий уровень сигнала датчика положения дроссельной заслонки "B"
P0224
Перемежающийся уровень сигнала датчика положения дроссельной заслонки "B"
P0225
Неисправность датчика положения дроссельной заслонки "C"
P0226
Сигнал датчика положения дроссельной заслонки вне допустимого диапазона "C"
P0227
Низкий уровень сигнала датчика положения дроссельной заслонки "C"
P0228
Высокий уровень сигнала датчика положения дроссельной заслонки "C"
P0229
Перемежающийся уровень сигнала датчика положения дроссельной заслонки "C"
P0230
Неисправность первичной цепи управления бензонасосом (упр. реле бензонасоса)
P0231
Постоянный низкий уровень вторичной цепи бензонасоса
P0232
Постоянный высокий уровень вторичной цепи бензонасоса
P0233
Перемежающийся уровень вторичной цепи бензонасоса
P0235
Неисправность цепи датчика давления турбонаддува "A"
P0236
Сигнал с датчика турбины "A" вне допустимого диапазона
P0237
Низкий уровень сигнала с датчика турбины "A"
P0238
Высокий уровень сигнала с датчика турбины "A"
P0239
Неисправность цепи датчика давления турбонаддува "B"
P0240
Сигнал с датчика турбины "B" вне допустимого диапазона
P0241
Низкий уровень сигнала с датчика турбины "B"
P0242
Высокий уровень сигнала с датчика турбины "B"
P0243
Неисправность соленоида затвора выхлопных газов турбины "A"
P0244
Сигнал соленоида затвора выхлопных газов турбины "A" вне доп. диапазона
P0245
Соленоид затвора выхлопных газов турбины "A" всегда открыт
P0246
Соленоид затвора выхлопных газов турбины "A" всегда закрыт
P0247
Неисправность соленоида затвора выхлопных газов турбины "B"
P0248
Сигнал соленоида затвора выхлопных газов турбины "B" вне доп. диапазона
P0249
Соленоид затвора выхлопных газов турбины "B" всегда открыт
P0250
Соленоид затвора выхлопных газов турбины "B" всегда закрыт
P0251
Неисправность насоса впрыска турбины"A"
P0252
Сигнал насоса впрыска турбины "A" не допустимого диапазона
P0253
Низкий уровень сигнала насоса впрыска турбины "A"
P0254
Высокий уровень сигнала насоса впрыска турбины "A"
P0255
Перемежающийся уровень сигнала насоса впрыска турбины "A"
P0256
Неисправность насоса впрыска турбины "B"
P0257
Сигнал насоса впрыска турбины "B" вне допустимого диапазона
P0258
Низкий уровень сигнала насоса впрыска турбины "B"
P0259
Высокий уровень сигнала насоса впрыска турбины "B"
P0260
Перемежающийся уровень сигнала насоса впрыска турбины "B"
P0261
Форсунка цилиндра №1 - замыкание на землю
P0262
Форсунка цилиндра №1 - обрыв или замыкание на +12V
P0263
Форсунка цилиндра №1 - неисправность драйвера форсунки
P0264
Форсунка цилиндра №2 - замыкание на землю
P0265
Форсунка цилиндра №2 - обрыв или замыкание на +12V
P0266
Форсунка цилиндра №2 - неисправность драйвера форсунки
P0267
Форсунка цилиндра №3 - замыкание на землю
P0268
Форсунка цилиндра №3 - обрыв или замыкание на +12V
P0269
Форсунка цилиндра №3 - неисправность драйвера форсунки
P0270
Форсунка цилиндра №4 - замыкание на землю
P0271
Форсунка цилиндра №4 - обрыв или замыкание на +12V
P0272
Форсунка цилиндра №4 - неисправность драйвера форсунки
P0273
Форсунка цилиндра №5 - замыкание на землю
P0274
Форсунка цилиндра №5 - обрыв или замыкание на +12V
P0275
Форсунка цилиндра №5 - неисправность драйвера форсунки
P0276
Форсунка цилиндра №6 - замыкание на землю
P0277
Форсунка цилиндра №6 - обрыв или замыкание на +12V
P0278
Форсунка цилиндра №6 - неисправность драйвера форсунки
P0279
Форсунка цилиндра №7 - замыкание на землю
P0280
Форсунка цилиндра №7 - обрыв или замыкание на +12V
P0281
Форсунка цилиндра №7 - неисправность драйвера форсунки
P0282
Форсунка цилиндра №8 - замыкание на землю
P0283
Форсунка цилиндра №8 - обрыв или замыкание на +12V
P0284
Форсунка цилиндра №8 - неисправность драйвера форсунки
P0285
Форсунка цилиндра №9 - замыкание на землю
P0286
Форсунка цилиндра №9 - обрыв или замыкание на +12V
P0287
Форсунка цилиндра №9 - неисправность драйвера форсунки
P0288
Форсунка цилиндра №10 - замыкание на землю
P0289
Форсунка цилиндра №10 - обрыв или замыкание на +12V
P0290
Форсунка цилиндра №10 - неисправность драйвера форсунки
P0291
Форсунка цилиндра №11 - замыкание на землю
P0292
Форсунка цилиндра №11 - обрыв или замыкание на +12
P0293
Форсунка цилиндра №11 - неисправность драйвера форсунки
P0294
Форсунка цилиндра №12 - замыкание на землю
P0295
Форсунка цилиндра №12 - обрыв или замыкание на +12V
P0296
Форсунка цилиндра №12 - неисправность драйвера форсунки
P0300
Обнаружены случайные/множественные пропуски зажигания
P0301
Обнаружены пропуски зажигания в цилиндре №1
P0302
Обнаружены пропуски зажигания в цилиндре №2
P0303
Обнаружены пропуски зажигания в цилиндре №3
P0304
Обнаружены пропуски зажигания в цилиндре №4
P0305
Обнаружены пропуски зажигания в цилиндре №5
P0306
Обнаружены пропуски зажигания в цилиндре №6
P0307
Обнаружены пропуски зажигания в цилиндре №7
P0308
Обнаружены пропуски зажигания в цилиндре №8
P0309
Обнаружены пропуски зажигания в цилиндре №9
P0310
Обнаружены пропуски зажигания в цилиндре №10
P0311
Обнаружены пропуски зажигания в цилиндре №11
P0312
Обнаружены пропуски зажигания в цилиндре №12
P0320
Неисправноcть цепи распределителя зажигания
P0321
Сигнал распределителя зажигания вне допустимого диапазона
P0322
Сигнал распределителя зажигания отсутствует
P0323
Сигнал распределителя зажигания перемежающийся
P0325
Неисправность цепи датчика детонации №1
P0326
Сигнал датчика детонации №1 вне допустимого диапазона
P0327
Низкий уровень сигнала датчика детонации №1
P0328
Высокий уровень сигнала датчика детонации №1
P0329
Перемежающийся уровень сигнала датчика детонации №1
P0330
Неисправность цепи датчика детонации №2
P0331
Сигнал датчика детонации №2 вне допустимого диапазона
P0332
Низкий уровень сигнала датчика детонации №2
P0333
Высокий уровень сигнала датчика детонации №2
P0334
Перемежающийся уровень сигнала датчика детонации №2
P0335
Ошибка датчика положения коленвала"A"
P0336
Ошибка ДПКВ "A" (пропуск одного зуба)
P0337
Низкий уровень или замыкание на массу ДПКВ "A"
P0338
Высокий уровень или замыкание на +12V ДПКВ "A"
P0339
Перемежающийся сигнал ДПКВ "A"
P0340
Неисправность датчика распределительного вала
P0341
Сигнал датчика распределительного вала вне допустимого диапазона
P0342
Низкий уровень сигнала датчика распределительного вала
P0343
Высокий уровень сигнала датчика распределительного вала
P0344
Перемежающийся уровень сигнала датчика распределительного вала
P0350
Неисправность первичной / вторичной цепи катушки зажигания
P0351
Неисправность первичной / вторичной цепи катушки зажигания "A"
P0352
Неисправность первичной / вторичной цепи катушки зажигания "B"
P0353
Неисправность первичной / вторичной цепи катушки зажигания "C"
P0354
Неисправность первичной / вторичной цепи катушки зажигания "D"
P0355
Неисправность первичной / вторичной цепи катушки зажигания "E"
P0356
Неисправность первичной / вторичной цепи катушки зажигания" F"
P0357
Неисправность первичной / вторичной цепи катушки зажигания "G"
P0358
Неисправность первичной / вторичной цепи катушки зажигания "H"
P0359
Неисправность первичной / вторичной цепи катушки зажигания "I"
P0360
Неисправность первичной / вторичной цепи катушки зажигания "J"
P0361
Неисправность первичной / вторичной цепи катушки зажигания "K"
P0362
Неисправность первичной / вторичной цепи катушки зажигания "L"
P0370
Неисправность сигнала А таймера
P0371
Число импульсов сигнала А таймера выше нормы
P0372
Число импульсов сигнала А таймера ниже нормы
P0373
Нестабильные импульсы сигнала А таймера
P0374
Нет импульсов сигнала А таймера
P0375
Неисправность сигнала B таймера
P0376
Число импульсов сигнала B таймера выше нормы
P0377
Число импульсов сигнала B таймера ниже нормы
P0378
Нестабильные импульсы сигнала B таймера
P0379
P0380
Неисправность свечи накаливания или цепи нагрева
P0381
Неисправность свечи накаливания или индикатора нагрева
P0385
Неисправность цепи датчика положения коленвала "B"
P0386
Сигнал датчика положения коленвала "B" вне допустимого диапазона
P0387
Низкий уровень или замыкание на массу ДПКВ "В"
P0388
Высокий уровень или замыкаение на +12V ДПКВ "В"
P0389
Перемежающийся сигнал датчика положения коленвала "B"
P0400
Неисправность системы рециркуляции отработанных газов
P0401
Неэффективность системы рециркуляции отработанных газов
P0402
Избыточность системы рециркуляции отработанных газов (ОГ)
P0403
Неисправность цепи датчика системы рециркуляции отработанных газов
P0404
Сигнал датчика системы рециркуляции ОГ вне допустимого диапазона
P0405
Низкий уровень сигнала датчика "A" системы рециркуляции ОГ
P0406
Высокий уровень сигнала датчика "A" системы рециркуляции ОГ
P0407
Низкий уровень сигнала датчика "В" системы рециркуляции ОГ
P0408
Высокий уровень сигнала датчика "В" системы рециркуляции ОГ
P0410
Неисправность системы вторичной подачи воздуха
P0411
Некорректный поток через систему вторичной подачи воздуха
P0412
Неисправность клапана системы вторичной подачи воздуха"A"
P0413
Клапан системы вторичной подачи воздуха "A" всегда открыт
P0414
Клапан системы вторичной подачи воздуха "A" всегда закрыт
P0415
Неисправность клапана системы вторичной подачи воздуха "В"
P0416
Клапан системы вторичной подачи воздуха "В" всегда открыт
P0417
Клапан системы вторичной подачи воздуха "В" всегда закрыт
P0420
Эффективность системы катализаторов В1 ниже допустимого порога
P0421
Эффективность прогрева катализаторов В1 ниже допустимого порога
P0422
Эффективность главного катализатора В1 ниже допустимого порога
P0423
Эффективность нагревателя катализатора В1 ниже допустимого порога
P0424
Температура нагревателя катализатора В1 ниже допустимого порога
P0430
Эффективность системы катализаторов В2 ниже допустимого порога
P0431
Эффективность прогрева катализаторов В3 ниже допустимого порога
P0432
Эффективность главного катализатора В2 ниже допустимого порога
P0433
Эффективность нагревателя катализатора В2 ниже допустимого порога
P0434
Температура нагревателя катализатора В2 ниже допустимого порога
P0440
Неисправность контроля системы улавливания паров бензина
P0441
Плохая продувка системы улавливания паров бензина
P0442
Небольшая утечка в системе улавливания паров бензина
P0443
Неисправность цепи клапана продувки системы улавливания паров бензина
P0444
Клапан продувки системы улавливания паров бензина всегда открыт
P0445
Клапан продувки системы улавливания паров бензина всегда закрыт
P0446
Неисправность упр. воздушным клапаном системы улавливания паров
P0447
Воздушный клапан системы улавливания паров всегда открыт
P0448
Воздушный клапан системы улавливания паров всегда закрыт
P0450
Неисправность датчика давления паров бензина
P0451
Сигнал датчика давления паров бензина вне допустимого диапазона
P0452
Низкий уровень сигнал датчика давления паров бензина
P0453
Высокий уровень сигнал датчика давления паров бензина
P0454
Перемежающийся уровень сигнал датчика давления паров бензина
P0455
Большая утечка в системе улавливания паров бензина
P0460
Неисправность цепи датчика уровня топлива
P0461
Сигнал датчика уровня топлива вне допустимого диапазона
P0462
Низкий уровень сигнала датчика уровня топлива
P0463
Высокий уровень сигнала датчика уровня топлива
P0464
Перемежающийся уровень сигнала датчика уровня топлива
P0465
Неисправность цепи датчика потока воздуха продувки
P0466
Сигнал датчика потока воздуха продувки вне допустимого диапазона
P0467
Низкий уровень сигнала датчика потока воздуха продувки
P0468
Высокий уровень сигнала датчика потока воздуха продувки
P0469
Перемежающийся уровень сигнала датчика потока воздуха продувки
P0470
Неисправность датчика давления выхлопных газов
P0471
Сигнал датчика давления выхлопных газов вне допустимого диапазона
P0472
Низкий уровень сигнала датчика давления выхлопных газов
P0473
Высокий уровень сигнала датчика давления выхлопных газов
P0474
Перемежающийся уровень сигнала датчика давления выхлопных газов
P0475
Неисправность клапана датчика давления выхлопных газов
P0476
Сигнал клапана датчика давления выхлопных газов вне допустимого диапазона
P0477
Низкий уровень сигнала клапана датчика давления выхлопных газов
P0478
Высокий уровень сигнала клапана датчика давления выхлопных газов
P0479
Перемежающийся уровень сигнала клапана датчика давления выхлопных газов
P0480
Неисправность цепи управления реле вентилятора
P0500
Нет сигнала датчика скорости автомобиля
P0501
Сигнал датчика скорости автомобиля вне допустимого диапазона
P0502
Низкий уровень сигнала датчика скорости автомобиля
P0503
Высокий уровень сигнала датчика скорости автомобиля
P0505
Неисправность регулятора холостого хода
P0506
Неисправность регулятора холостого хода - низкие обороты
P0507
Неисправность регулятора холостого хода - высокие обороты
P0510
Неисправность концевика дроссельной заслонки
P0520
Неисправность в цепи датчика давления масла
P0521
Неправильный показатель/не отрегулирован датчик давления масла
P0522
Низкое напряжение датчика давления масла
P0523
Высокое напряжение датчика давления масла
P0530
Неисправность в цепи датчика давления охлаждающей жидкости кондиционера
P0531
Неправильный показатель/не отрегулирован датчик давления охлаждающей жидкости кондиционера
P0532
Низкий показатель датчика давления охлаждающей жидкости кондиционера
P0533
Высокий показатель датчика давления охлаждающей жидкости кондиционера
P0534
Утечка охлаждающей жидкости кондиционера
P0550
Неисправность в цепи датчика давления в гидроусилителе руля
P0551
Неправильный показатель/не отрегулирован датчик давления в гидроусилителе руля
P0552
Низкий показатель датчика давления в гидроусилителе руля
P0553
Высокий показатель датчика давления в гидроусилителе руля
P0554
Неисправность датчика давления в гидроусилителе руля
P0560
Напряжение питания системы ниже порога работоспособности
P0561
Напряжение питания системы нестабильное
P0562
Низкое напряжение питания системы
P0563
Высокое напряжение питания системы
P0565
Неисправность сигнала включения системы круиз-контроля
P0566
Неисправность сигнала выключения системы круиз-контроля
P0567
Неисправность сигнала продолжения движения системы круиз-контроля
P0568
Неисправность сигнала установки скорости системы круиз-контроля
P0569
Неисправность сигнала торможения системы круиз-контроля
P0570
Неисправность сигнала ускорения системы круиз-контроля
P0571
CНеисправность в цепи переключателя торможения A системы круиз-контроля
P0572
Низкий показатель переключателя торможения A системы круиз-контроля
P0573
Высокий показатель переключателя торможения A системы круиз-контроля
P0574
Неисправность системы круиз-контроля
P0575
P0576
P0577
P0578
P0579
P0580
P0600
Неисправность при связи с системой
P0601
Ошибка контрольной суммы ПЗУ
P0602
Программная ошибка блока управления
P0603
Ошибка внешнего ОЗУ
P0604
Ошибка внутреннего ОЗУ
P0605
Ошибка в памяти (ROM) блока управления
P0606
Неисправность процессора PCM
P0607
Неисправность канала детонации
P0608
Неисправность датчика VSS "A" блока управления
P0609
Неисправность датчика VSS "В" блока управления
P0620
Неисправность в цепи управления генератора
P0621
Неисправность в цепи лампы "L" генератора
P0622
Неисправность в блоке "F" генератора
P0650
Неисправность в цепи индикаторной лампы неисправностей (MIL)
P0654
Неправильно отрегулированы обороты двигателя
P0655
Неисправность в цепи лампы прогрева двигателя
P0656
Неисправность в цепи датчика уровня топлива
P0700
Неисправность системы контроля трансмиссии
P0701
Система контроля трансмиссии вне допустимого диапазона
P0702
Электрическая система контроля трансмиссии
P0703
Неисправность в цепи датчика B уменьшения крутящего момента при торможении
P0704
Неисправность в цепи датчика сцепления
P0705
Неисправность в цепи датчика трансмиссии (PRNDL)
P0706
Неправильный показатель / не отрегулирован датчик трансмиссии
P0707
Низкий показатель датчика трансмиссии
P0708
Высокий показатель датчика трансмиссии
P0709
Неисправность датчика трансмиссии
P0710
Неисправность в цепи датчика температуры трансмиссионной жидкости
P0711
Неправильный показатель / не отрегулирован датчик температуры трансмиссионной жидкости
P0712
Низкий показатель датчика температуры трансмиссионной жидкости
P0713
Высокий показатель датчика температуры трансмиссионной жидкости
P0714
Неисправность датчика температуры трансмиссионной жидкости
P0715
Неисправность в цепи датчика оборотов турбины
P0716
Неправильный показатель / не отрегулирован датчик оборотов турбины
P0717
Нет сигнала от датчика оборотов турбины
P0718
Неисправность датчика оборотов турбины
P0719
Низкий показатель цепи датчика B уменьшения крутящего момента при торможении
P0720
Неисправность в цепи датчика частоты вращения вала
P0721
Неправильный показатель / не отрегулирован датчик частоты вращения вала
P0722
Нет сигнала от датчика частоты вращения вала
P0723
Неисправность датчика частоты вращения вала
P0724
Высокий показатель цепи датчика B уменьшения крутящего момента при торможении
P0725
Неисправность в цепи датчика оборотов двигателя
P0726
Неправильный показатель / не отрегулирован датчик оборотов двигателя
P0727
Нет сигнала от датчика оборотов двигателя
P0728
Неисправность датчика оборотов двигателя
P0730
Неправильно отрегулирована коробка передач
P0731
Неправильно отрегулирована 1 передача
P0732
Неправильно отрегулирована 2 передача
P0733
Неправильно отрегулирована 3 передача
P0734
Неправильно отрегулирована 4 передача
P0735
Неправильно отрегулирована 5 передача
P0736
Неправильно отрегулирована задняя передача
P0740
Неисправность в цепи муфты сцепления
P0741
Неправильно отрегулирована муфта сцепления
P0742
Повреждена муфта сцепления
P0743
Повреждение электрической цепи муфты сцепления
P0744
P0745
Неисправность в цепи соленоида давления
P0746
Неправильно отрегулирован соленоид давления
P0747
Поврежден соленоид давления
P0748
Повреждение электрической цепи соленоида давления
P0749
Неисправность соленоида давления
P0750
Неисправность переключателя А соленоида
P0751
Неправильно отрегулирован переключатель А соленоида
P0752
Повреждение переключателя А соленоида
P0753
Повреждение электрической цепи переключателя А соленоида
P0754
P0755
Неисправность переключателя B соленоида
P0756
Неправильно отрегулирован переключатель B соленоида
P0757
Повреждение переключателя B соленоида
P0758
Повреждение электрической цепи переключателя B соленоида
P0759
P0760
Неисправность переключателя C соленоида
P0761
Неправильно отрегулирован переключатель C соленоида
P0762
Повреждение переключателя C соленоида
P0763
Повреждение электрической цепи переключателя C соленоида
P0764
P0765
Неисправность переключателя D соленоида
P0766
Неправильно отрегулирован переключатель D соленоида
P0767
Повреждение переключателя D соленоида
P0768
Повреждение электрической цепи переключателя D соленоида
P0769
P0770
Неисправность переключателя E соленоида
P0771
Неправильно отрегулирован переключатель E соленоида
P0772
Повреждение переключателя E соленоида
P0773
Повреждение электрической цепи переключателя E соленоида
P0774
P0780
P0781
Неисправность 1-2 переключателей
P0782
Неисправность 2-3 переключателей
P0783
Неисправность 3-4 переключателей
P0784
Неисправность 4-5 переключателей
P0785
P0786
Неправильный показатель / не отрегулирован соленоид
P0787
Низкий показатель датчика соленоида
P0788
Высокий показатель датчика соленоида
P0789
P0790
Неисправность в цепи переключателя в режим normal
P0801
Неисправность в цепи контроля системы Reverse Inhibit
P0803
Неисправность в цепи соленоида переключателя 1-4
P0804
Неисправность в цепи контрольной лампы переключателя 1-4
Коды устанавливаемые производителям. Зависят от марки авто.
P1000
OBD II Monitor не проходит тест
P1001
Key On Engine Running (KOER) Self-Test not able to complete. KOER aborted
P1100
Mass Air Flow (MAF) sensor intermittent
P1101
Mass Air Flow (MAF) sensor out of Self-Test range
P1102
Низкое сопротивление подогревателя датчика кислорода
Р1106
Высокое напряжение в цепи датчика абсолютного давления впускного коллектора (MAP)
Р1107
Низкое напряжение в цепи датчика абсолютного давления впускного коллектора (MAP)
P1110
Switch over valve solenoid
P1111
Высокое напряжение в цепи датчика температуры воздуха на впуске (IAT)
P1112
Switch over valve 1
Низкое напряжение в цепи датчика температуры воздуха на впуске (IAT)
P1113
Switch over valve 2
P1114
Низкое напряжение в цепи датчика температуры охлаждающей жидкости (ECT)
P1115
Высокое напряжение в цепи датчика температуры охлаждающей жидкости (ECT)
P1116
О2 Sensor heater Circuit (Open)
Датчик температуры двигателя (ECT) не прошел самотестирование
P1117
Датчик температуры двигателя (ECT) sensor intermittent
P1120
Датчик положения дросселя (TP) out of range low
P1121
Высокое напряжение в цепи датчика положения дроссельной заслонки (TP)
P1122
Низкое напряжение в цепи датчика положения дроссельной заслонки (TP)
P1123
Long Term Fuel Trim Additive Air (System too Rich)
P1124
Датчик положения дросселя (TP) sensor out of Self -Test range
Long Term Fuel Trim Additive Air (System too Lean)
P1125
Датчик положения дросселя (TP) sensor circuit intermittent
P1127
Exhaust not warm enough, downstream Heated Oxygen Sensors (HO2Ss) not tested
Long Term Fuel Trim Multiplicative (System too Rich)
P1128
Upstream Heated Oxygen Sensors (HO2Ss) swapped from bank to bank
Long Term Fuel Trim Multiplicative (System too Lean)
P1129
Downstream Heated Oxygen Sensors (HO2Ss) swapped from bank to bank
P1130
Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, adaptive fuel at limit (Bank # 1)
P1131
Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, sensor indicates lean (Bank # 1))
P1132
Lack of upstream Heated Oxygen Sensor (HO2S 11) switch, sensor indicates rich (Bank # 1)
P1133
Датчик 1 HO2S
P1134
Таймер включения датчика HO2S
P1136
Long Term Fuel Trim Additive Fuel (System too Rich)
P1137
Lack of downstream Heated Oxygen Sensor (HO2S 12) switch, sensor indicates lean (Bank # 1)
Long Term Fuel Trim Additive Fuel (System too Lean)
P1138
Lack of downstream Heated Oxygen Sensor (HO2S 12) switch, sensor indicates rich (Bank # 1)
P1140
Неверный сигнал нагрузки
P1150
Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, adaptive fuel at limit (Bank #2)
P1151
Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, sensor indicates lean (Bank # 2)
P1152
Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, sensor indicates rich (Bank # 2)
P1157
Lack of downstream Heated Oxygen Sensor (HO2S 22) switch, sensor indicates lean (Bank # 2)
P1158
Lack of downstream Heated Oxygen Sensor (HO2S 22) switch, sensor indicates rich (Bank # 2)
P1171
Низкий уровень сигнала СО-потенциометра
P1172
Высокий уровень сигнала СО-потенциометра
P1174
02 Sensor 1 Bank 1 (period monitoring)
P1176
02 Sensor 1 Bank 1 (tv monitoring)
P1200
Цепь управления форсункой
P1220
Series Throttle Control system malfunction
P1224
Датчик положения дросселя B (TP-B) out of Self - Test range
P1229
Power Supply Relay Primary Circuit Voltage High
P1230
Power Supply Relay Secondary Circuit Voltage Low
P1231
Fuel pump relay circuit low with high speed pump on
P1232
Low speed Fuel Pump primary circuit malfunction
P1233
Fuel Pump Driver Module disabled or offline
P1234
P1235
Fuel Pump control out of Self - Test range
P1236
Не считывается показатель датчика положения коленвала (CKP)
P1237
Fuel Pump secondary circuit malfunction
P1238
P1260
Попытка угона - запуск заблокирован
P1270
Engine RPM or vehicle speed limiter reached
P1285
Неисправность датчика температуры ГБЦ
P1288
Датчик температуры ГБЦ (CHT) sensor out of Self - Test range
P1289
Датчик температуры ГБЦ (CHT) sensor circuit low input
P1290
Датчик температуры ГБЦ (CHT) sensor circuit high input
P1299
Engine over temperature condition
P1326
Knock Control Maximum Spark Limit Cylinder 1
P1327
Knock Control Maximum Spark Limit Cylinder 2
P1328
Knock Control Maximum Spark Limit Cylinder 3
P1329
Knock Control Maximum Spark Limit Cylinder 4
P1350
Запасная линия мониторинга
P1351
Ignition Diagnostic Monitor (IDM) circuit input malfunction
P1356
PIPS occurred while IDM pulse width indicates engine not turning
P1357
Ignition Diagnostic Monitor (IDM) pulse width not defined
P1358
Ignition Diagnostic Monitor (IDM) signal out of Self - Test range
P1359
Spark output circuit malfunction
P1361
Низкое напряжение в цепи контроля зажигания (IC)
P1374
Изменение частоты датчика положения коленвала (CKP)
P1380
Неисправность в системе – невозможно считать данные
P1386
Knock control Testpulse
P1390
Octane Adjust (OCT ADJ) out of Self - Test range
P1400
Differential Pressure Feedback EGR (DPFE) sensor circuit low voltage detected
P1401
Differential Pressure Feedback EGR (DPFE) sensor circuit high voltage detected
P1405
Differential Pressure Feedback EGR (DPFE) sensor upstream hose off or plugged
P1406
Differential Pressure Feedback EGR (DPFE) sensor downstream hose off or plugged
Регулировка датчика системы рециркуляции выхлопных газов (EGR)
P1408
Exhaust Gas Recirculation (EGR) flow out of Self - Test range
P1409
Canister purge valve power stage (malfunction)
Electronic Vacuum Regulator (EVR) control circuit malfunction
P1410
Canister purge valve power stage (high)
Secondary air pump relay
P1411
Secondary Air Injection system incorrect downstream flow detected
P1413
Secondary Air Injection system monitor circuit low voltage
P1414
Secondary Air Injection system monitor circuit high voltage
P1425
Canister purge valve power stage (low)
Цепь управления клапаном продувки адсорбера, замыкание на землю
P1426
Цепь управления клапаном продувки адсорбера, обрыв
P1441
Расход в системе отвода паров топлива (EVAP) только для автомобиля Chevrolet
Расход в системе отвода паров топлива (EVAP) только для автомобиля Oldsmobile
P1442
Evaporative emission control system small leak detected
P1443
Evaporative emission control system - vacuum system, purge control solenoid or vapor management valve malfunction
P1444
Purge Flow (PF) Sensor circuit low input
P1445
Purge Flow (PF) Sensor circuit high input
P1449
Evaporative emission control system unable to hold vacuum (Probe)
P1450
Unable to bleed up fuel tank vacuum
P1452
P1455
Evaporative emission control system control leak detected (gross leak)
P1460
Wide Open Throttle Air Conditioning Cutoff (WAC) circuit malfunction
P1461
Air Conditioning Pressure (ACP) sensor circuit low input
P1462
Air Conditioning Pressure (ACP) sensor circuit high input
P1463
Air Conditioning Pressure (ACP) sensor insufficient pressure change
P1464
Air Condition (A/C) demand out of Self - Test range
P1469
Low air conditioning cycling period
P1473
Fan secondary high with fan(s) off
P1474
Low Fan Control primary circuit malfunction
P1479
High Fan Control primary circuit malfunction
P1480
Fan secondary low with low fan on
P1481
Fan secondary low with high fan on
P1483
Power to fan circuit over current
P1484
Open power ground to Variable Load Control Module (VLCM)
P1500
Неисправность цепи реле топливного насоса
P1501
Иммобилайзер - нет кода или неправильный код
Реле топливного насоса - замыкание на землю
P1502
Реле топливного насоса - замыкание на +12V
Иммобилайзер - нет сигнала
P1503
Иммобилайзер - неправильный сигнал
P1504
Idle Air Control (IAC) circuit malfunction
P1505
Idle Air Control (IAC) system at adaptive clip
P1506
Idle Air Control (IAC) overspeed error
P1507
Idle Air Control (IAC) under speed error
P1509
Цепь управления регулятором холостого хода, перегрузка
P1512
Intake Manifold Runner Control (IMRC) malfunction (Bank # 1 stuck closed)
P1513
Intake Manifold Runner Control (IMRC) malfunction (Bank # 2 stuck closed)
Цепь управления регулятором холостого хода - замыкание на землю
P1514
Цепь управления регулятором холостого хода - обрыв
P1516
Intake Manifold Runner Control (IMRC) input error (Bank # 1)
P1517
Intake Manifold Runner Control (IMRC) input error (Bank # 2)
P1518
Intake Manifold Runner Control (IMRC) malfunction (stuck open)
P1519
Intake Manifold Runner Control (IMRC) malfunction (stuck closed)
P1520
Intake Manifold Runner Control (IMRC) circuit malfunction
P1530
Air Condition (A / C) clutch circuit malfunction
P1537
Intake Manifold Runner Control (IMRC) malfunction (Bank # 1 stuck open)
P1538
Intake Manifold Runner Control (IMRC) malfunction (Bank # 2 stuck open)
P1539
Power to Air condition (A / C) clutch circuit overcurrent
P1541
Цепь управления реле бензонасоса, обрыв
P1550
Power steering Pressure (PSP) sensor out of Self - Test range
P1554
Цепь обратной связи с системой круиз-контроля
P1570
Обрыв цепи иммобилизатора
P1600
Нет связи с иммобилизатором
Reprogram or Replace Electronic Control Unit (ECM)
P1601
ECM Box Temperature High
P1602
Пропадание напряжения контроллера
Модуль контроля детонации
P1603
Ошибка EEPROM
P1604
Устройство контроля детонации
P1605
P1606
P1612
Ошибка сброса процессора
P1619
Electrical Thermostat Control powerstage (too high)
P1620
Ошибка ПЗУ
Electrical Thermostat Control powerstage (too low)
P1621
Ошибка OЗУ
P1622
Ошибка EEPROM
Electrical Thermostat Control powerstage (Range/Perfomance)
P1625
B(+) supply to ariable Load Control Module (VCLM) fan circuit malfunction
P1626
B(+) supply to Variable Load Control Module (VCLM) Air Condition (A / C) circuit malfunction
Потеря сигнала от топливной системы
P1629
Не поступает сигнал от топливной системы
P1635
Цепь 5 вольт, только для автомобиля Oldsmobile
Цепь 5 вольт, только для автомобиля Chevrolet
P1639
2 цепь 5 вольт, только для автомобиля Oldsmobile
2 цепь 5 вольт, только для автомобиля Chevrolet
P1640
Устройство контроля детонации или модуль полного привода
P1641
Контрольная цепь индикаторной лампы неисправностей (MIL)
P1650
Power Steering Pressure (PSP) switch out of Self - Test range
P1651
Power Steering Pressure (PSP) switch input malfunction
Контрольная цепь 1 реле вентилятора, только для автомобиля Oldsmobile
Контрольная цепь 1 реле вентилятора, только для автомобиля Chevrolet
P1652
Контрольная цепь 2 реле вентилятора, только для автомобиля Oldsmobile
Контрольная цепь 2 реле вентилятора, только для автомобиля Chevrolet
P1654
Контрольная цепь реле кондиционера (A/C)
P1655
Контрольная цепь соленоида системы отвода паров топлива (EVAP), только для автомобиля Oldsmobile
Контрольная цепь соленоида системы отвода паров топлива (EVAP), только для автомобиля Chevrolet
P1662
Цепь системы круиз-контроля
P1663
Контрольная лампа перезарядки
P1671
Контрольная лампа замены масла
P1672
Контрольная лампа низкого уровня масла
P1675
P1689
Ошибка памяти ошибок
P1690
Ошибка лампы диагностики
MIL-on requestsignal (Malfunction)
P1693
MIL-on requestsignal (High)
P1701
Reverse engagement error
P1703
Brake On/Off (BOO) switch out of Self - Test range
P1705
Transmission Range (TR) Sensor out of Self - Test range
P1709
Park or Neutral Position (PNP) switch is not indicating neutral during KOEO Self - Test
P1711
Transmission Fluid Temperature (TFT) sensor out of Self - Test range
P1728
Transmission slip fault
P1729
4x4 Low switch error
P1740
Torque Control unit
P1741
Torque Converter Clutch (TCC) control error
P1742
Torque Converter Clutch (TCC) solenoid failed on (turns on MIL)
P1743
Torque Converter Clutch (TCC) solenoid failed on (turns on TCIL)
P1744
Torque Converter Clutch (TCC) system mechanically stuck in off position
P1746
Electronic Pressure Control (EPC) solenoid open circuit (low input)
P1747
Electronic Pressure Control (EPC) solenoid short circuit (high input)
P1749
Electronic Pressure Control (EPC) solenoid failed low
P1751
Shift Solenoid # 1 (SS1) performance
P1754
Coast Clutch Solenoid (CCS) circuit malfunction
P1756
Shift Solenoid # 2 (SS2) performance
P1761
Shift Solenoid # 3 (SS3) performance
P1780
Transmission Control switch (TCS) circuit out of Self - Test range
P1781
4x4 Low switch out of Self - Test range
P1783
Transmission over temperature condition
P1788
3-2 Timing / Coast Clutch Solenoid (3-2 / CCS) circuit open
P1789
3-2 Timing / Coast Clutch Solenoid (3-2 / CCS) circuit shorted
U1021
SCP indicating the lack of Air Condition (A/C) clutch status response
U1039
SCP indicating the vehicle speed signal missing or incorrect
U1051
SCP indicating the brake switch signal missing or incorrect
U1073
SCP indicating the lack of engine coolant fan status response
U1131
SCP indicating the lack of Fuel Pump status response
U1135
SCP indicating the ignition switch signal missing or incorrect
U1256
SCP indicating a communications error
U1451
Lack of response from Passive Anti-Theft system (PATS) module - engine disabled
Список наиболее употребительных сокращений по OBD II
AFC – Расходомер воздуха
ALDL – Диагностический коннектор. Так раньше назывался диагностический коннектор для автомобилей GM, а также разъем для подключения сканнера; также может использоваться как название любых сигналов OBD II
CAN - Контроллер
CARB – Калифорнийский совет по атмосферным ресурсам
CFI – центральный впрыск топлива (TBI)
CFI – непрерывный впрыск топлива
CO – монооксид углерода
DLC – Диагностический коннектор
Driving Cycle – Последовательность пуска, прогрева и движения автомобиля, в ходе этого цикла происходит тестирование всех функций OBD II
DTC – Код неисправности
ECM – Блок управления двигателем
EEC – Электронное управление двигателем
EEPROM or E2PROM – Программируемая память, доступная только для чтения
EFI – электронный впрыск топлива
EGR - рециркуляция выхлопных газов
EMR – электронный блок уменьшения угла зажигания
EPA – Совет по охране окружающей среды
ESC – Электронная регулировка зажигания
EST – Электронная регулировка момента зажигания
Fuel Trim – балансировка состава смеси
HC - углеводород
HEI - зажигание
HO2S – подогрев датчика кислорода
ISO 9141 – международный стандарт для разъема OBD II
J1850PWM – протокол для разъема OBD II, установленный по стандарту SAE
J1850VPW - протокол для разъема OBD II, установленный по стандарту SAE
J1962 – стандарт для диагностического коннектора OBD II, установленный по стандарту SAE
J1978 – стандарт SAE для сканнеров OBD II
J1979 – стандарт SAE для режимов диагностики
J2012 – стандарт SAE, одобренный EPA, для сообщений при тестировании системы выхлопных газов
MAF – расход воздуха
MAP – абсолютное давление во впускном коллекторе
MAT – температура воздуха во впускном коллекторе
MIL – индикаторная лампа неисправностей. Лампа "Check Engine Light" на панели приборов.
NOx – оксид азота
O2 - кислород
OBD - диагностика
OBD II or OBD II – усовершенствованный стандарт для диагностики автомобилей в США после 1-1-96
Parameters – Параметры по диагностике OBD II
PCM – Блок управления трансмиссией
PCV - Картер
Proprietary Readings – Параметры бортового компьютера, которые не требуются для диагностики OBD II, но могут использоваться для диагностики неисправностей различных типов автомобилей.
PTC – Код неисправности
RPM – об/мин
Scan Tool - сканнер
SES – лампа сервисного обслуживания двигателя на панели приборов
SFI – последовательный впрыск топлива
Stoichiometric ( Stoy'-kee-o-metric) Ratio – Коэффициент сгорания топлива
TPS – Датчик положения дроссельной заслонки
VAC - вакуум
VCM – центральный блок управления автомобиля
VIN – идентификационный номер автомобиля
VSS – датчик скорости
WOT – открытая дроссельная заслонка
Lotsman
сообщение 25.2.2011, 10:10
Из: Кузбасс
Пользователь №: 13801
Ошибка C168B как расшифровать?
И вот еще B15D8.
Сообщение отредактировал Lotsman - 25.2.2011, 12:01
сообщение 28.2.2011, 13:24
точную распечатку не дали, но сказали что это по CAN линии проблема... скорее всего сигнал не доходит
И вот еще B15D8
а эта конкретно отсоединён штеккер в самой "голове", может контакт слабый или окислился.
В общем начни с головного монитора... а так надо все контакты проверять 003_wink.gif
Lotsman
сообщение 1.3.2011, 17:05
Из: Кузбасс
А еще В15С2 это что такое?
сообщение 2.3.2011, 12:07
Lotsman
сообщение 2.3.2011, 13:48
Из: Кузбасс
Цитата(Roma @ 2.3.2011, 13:07) *
Она тоже связана с отсутствием сигнала от камены на мониторе, интересно чем отличается от предыдущей ошибки.
сообщение 18.5.2011, 7:57
Надписи и сокращения
А ampere(s) - ампер
ABS - антиблокировочная система тормозов
А/С (air conditioner) - воздушный кондиционер
АСС - положение замка зажигания (включен стеклоочиститель, радио, прикуриватель)
АСС (accessary) - добавочное питание
ACCEL (accelerator) - педаль газа
ACL (air cleaner) - воздухоочиститель
ADJ ADJUST - регулировка
A/F (air fuel ratio) - состав топливновоздушной смеси
AIR FLOW METER - датчик расхода воздуха
ALB - антиблокировочная система
ALT (alternator) - генератор
ALT (altitude) - высота
AM 1 - питание первой группы контактов замка зажигания
AM 2 - питание второй группы контактов замка зажигания
АМР - см. А
ANT (antenna) - антенна
APS - режим перемотки "автопоиск паузы" в магнитофоне
ASM (assembly) - сборка
А/Т - автоматическая трансмиссия
ATDC - после верхней мертвой точки
ATF (automatic transmission fluid) - жидкость для автоматической трансмиссии
ALTO (automatic) - автоматический
В (battery) - батарея
BACK UP - задний ход
BAND - диапазон (у радиоприемника)
BARO (barometric pressure) - атмосферное давление
ВАТ - см. В
BEAM - дальний свет
BELT - ремень
BLOWER MOTOR - мотор отопителя салона (он же кондиционера)
BOOST - величина вакуума во впускном коллекторе
BRAKE - тормоз
BREAKER - тепловой размыкатель (предохранитель многократного действия)
BTDS - до верхней мертвой точки
С см. CONTROL
САС (charge air coder) охладитель всасываемого воздуха
CAM CAMSHAFT распределительный вал
СС кубический сантиметр
CDS FAN (condenser fan motor) мотор вентилятора, охлаждение конденсора (радиатора кондиционера)
CHECK проверка
CHECK CONNECTOR проверочный разъем
CHG CHARGE зарядка
CHOKE воздушная заслонка
CI центральный впрыск
CIG FUSE предохранитель прикуривателя
СКР (crankshaft position) положение коленчатого вала
СМН (cold mixture heater) нагреватель топливной смеси
СМР (camshaft position) положение распредвала
СО (carbon monoxide) окись углерода
COLD холод
CONTROL управление
CRANK (crankshaft) коленчатый вал
D DRIVE движение
DEF (defogger) размораживатель , подогрев заднего (переднего) стекла
DI (distributor ignition) распределить зажигания
DITRIBUTOR трамблер
DOHC (double overhead camshaft) двойной распредвал в головке блока
DOME панель приборов, салон
DOOR CONTROL управление дверью
DOWN вниз
DTS (diagnostic trouble code) коды самодиагностики
DTM (diagnostic tast mode) режим диагностики
E END конец (топлива)
Е EARTH "земля" (корпус)
EAI подача воздуха в выпускную систему
ЕВСМ (electronic brake control module) электронный блок управления тормозами
ЕСС ( emission control computer) блок управления выбросами (испарениями) двигателя
ECI электронный центральный впрыск (тоже CI)
ЕСМ (engine control module) см. ECV
ECON ECONOMY экономичный (режим работы)
ЕСТ (electronic control transmission) электронное учравление трансмиссией
ЕСТ (engine coolant temperature) температура двигателя
ECU (electric control unit) электрический блок управления
EFI электронный впрыск топлива
EGR (exhaust gas i ^circulation) возврат выхлопных газов
ENG ENGINE двигатель
EPS электронное управление амортизаторами
EST S см. ЕСТ
EVAP (evaporative) система отсоса паров (из бензобака)
F (front) перед
F (full) полный (уровень топлива)
F (или FF). FORWARD вперед
FAST быстро
FAN MOTOR мотор вентилятора
FAN I/UP RELAY реле повышения оборотов холостого хода при включении вентилятора
FC (FCUT) FUEL CUT отсечка топлива
FL (fusible link) предохранительная вставка
FLUID жидкость
FOG LIGHTS противотуманные фары
FP см. FUEL PAMP
FREE свободно
FUEL топливо
FUEL PAMP топливный насос
FUSE предохранитель
FUSIBLE LINK предохранительная линия
FWD (front wheel drive) передний привод
GAUGE датчик
GLOG PLUG свеча накаливания
Н (hard) жестко (режим подвески)
Н (hocr) час
Н или Hi (high) высокие (обороты), высокая (передача, температура)
НАС (high altitude compensation) система компенсации атмосферного давления
HAI (hot air system) система подачи горячего воздуха во впускной коллектор (при работе двигателя на сильном морозе)
HAZ (hazard) аварийная сигнализация
HEAD LN левая фара
HEAD RH правая фара
HEAD RH LWR правая фара ближнего света
HEAD RH UPR правая фара дальнего света
HORN сигнал
НОТ горячий
HTR (heater) нагреватель
IAC (idle air control) управление воздухом в режиме холостого хода
IDL (idle) холостой ход
IDL/UP см. I/UP
IG (IGN) igniter коммутатор
IG (IGN) ignition зажигание
IGNITION COIL катушка зажигания
НА ignition integral assemble интегральная сборка зажигания
INJECTOR инжектор
INT interval интервал
I/UP idle up увеличение оборотов холостого хода
L (low) низкие (обороты), низкая (передача, температура)
L (left) левое (зеркало, положение)
LEVEL уровень
LF (left front) левый передний
LH (left hand) левая рука
LO см. L
LOCK блокировка
LR (left rear) левый задний
LS (left side) левый боковой
М (medium) середина
М (memory) память
М (minute) минута
М см. MANU
MAP (mass air flow) измеритель объема воздуха
MAIN RELAY главное реле
MAN см. MANU
MANU ручное (управление, регулировка)
МС (mixture control) управление составом смеси
MIL (malfunction indicator lamp) лампа неисправности ("check")
MIRROR зеркало заднего вида
MODE выбор режима
MPI многоточечный впрыск
М/Т механическая трансмиссия
N neutral нейтральное (положение)
N normal нормальное (состояние)
0/D over drive повышенная передача
2 WAY 0/D автоматическое отключение повышенной передачи
ОНС (overhead camshaft) распредвал в головке блока цилиндров
OFF выключено
OIL масло
ON включено
OX SENSOR датчик кислорода
Р PARKING стоянка
РСВ (POWER CB) power control block силовой блок управления (обычно блок управления дверьми, стеклами)
PCV (positive crancase ventilation) система вентиляции картера
PPS (progressive power steering) система управления усилия на руле
PRE HEATING TIMER реле времени предварительного нагрева (обычно свечей накаливания)
PUMP насос
PULL потянуть
PUSH нажать
PWR (power) мощностной режим
QUICK быстро
R (return) возвращение, назад
R (right) правое (зеркало, положение)
RDI FAN (radiator fan motor) мотор вентилятора радиатора охлаждения двигателя
REAR DOOR задняя дверь
REAR WASHER MOTOR мотор заднего отмывателя стекла
REAR WINDOW DEFOGGER обогреватель заднего стекла
RELAY реле
RESET установка
REV (reversal) изменение направления
RICH богатая (смесь)
R.P.M. обороты в минуту
RR REAR задний (например, RRDEF задний размораживатель)
RTR MOTOR retract motor мотор открытиязакрытия фар S (soft) мягкий
SAE (Society of Automotive Engineers) общество автомобильных инженеров
SEAT HTR seat heater подогрев сидений
SEEK поиск
SELECT выбор (режима)
SENSOR датчик
SET установка
SLOW медленно
SOHC (singl overhead camshaft) один распредвал в головке блока
SPD SPEED скорость
SPORT (S) спортивный (режим)
ST STARTER стартер
SUN ROOF люк в крыше автомобиля
S/W (switch) выключатель
TAIL габаритные (огни)
ТВ (throttle body) блок дроссельной заслонки
TEMS (Toyota electronic modolated suspension) см. EPS
TDS (top dead center) верхняя мертвая точка
TEMP (temperature) температура
THROTTLE POSITION SENSOR датчик положения дроссельной заслонки
THA temperature heat air температура воздуха
TGH температура выхлопных газов
THW temperature heat water температура воды ("Тосола")
TRN TURN поворот
TURN RELAY реле поворотов
UP вверх
VACUUM SENSOR датчик вакуума
VALVE клапан
VSV (vacum solenoid valve) электромагнитный клапан на вакуумной магистрали
WARMER нагреватель
W (warning) предупреждение
WASHER омыватель
WATER вода
WD (wheel drive) ведущие колеса
WIPER стеклоочиститель
WINDOW стекло
WS (wheel steer) управляемые колеса
4WD (four wheel drive) полный привод
4А/Т четырехскоростная автоматическая коробка передач
Текстовая версия Сейчас: 2.11.2026, 6:07
