1.8.2007, 12:30
Здравствуйте! Собираюсь брать TLC PRADO 2007 в комплектации GX 8 SAFARI SPLA/T FLR. Не могу понять какой двигатель стоит - написано 2,7 VVTi? что это 2TR или 3RZ. По коням написано 160 на 4800. Поясните кто сможет...
Вообще стоит брать или нет? Спецификация: Basic BASE MODEL MAKE TOYOTA MODEL NAME PRADO GRADE GX 8 SAFARI SPLA/T FLR MODEL CODE/SFX TRJ120L-GKPEKV/TRJ-24 DIMENSIONS DIMENSIONS Lx Wx H (mm) 4925 X 1875 X 1865 WHEEL BASE (mm) 2790 GROUND CLEARANCE (mm) 220 MIN. TURNING RADIUS(M) 5,7 FUEL TANK CAPACITY (Ltrs) 87 ENGINE & DISPLACEMENT cc 2694 DRIVETRAIN HP / RPM SAE Gross (Net) (160/4800) TORQUE KgM/RPM SAE Gross(Net) (25.1/4000) TYPE L4,DOHC,16V FUEL SYSTEM EFi, VVTi FUEL TYPE UNLEADED GASOLINE CATALYTIC CONVERTER WITH T/M 4-SPEED A/T 4WD OPTIONS FULL TIME DIFF. OPTION LSD (CENTRE DIFF.) TIRE TIRE SIZE 265/65 R 17 WHEEL CAP ALLOY STEERING POWER/TILT WITH/WITH TELESCOPIC WITHOUT BRAKE FRONT/REAR V.DISC/DISC LSPV WITH SUSPENSION FRONT DOUBLE WISHBONE REAR 4-LINK COIL Safety ABS WITH SIDE IMPACT BEAM WITH AIR BAG D+P Exterior BUMPER Fr. & Rr. COLOUR KEYED MUD GUARDS Fr. & Rr. FR+RR WINDSHIELD GLASS GREEN TLWG REAR SPOILER WITH SUN/MOON ROOF WITHOUT SIDE PROTECTION MOULDING WITH CLADDING SIDE STRIPE WITHOUT HIGH MOUNT STOP LAMP WITH OUTER MIRRORS COLOUR KEYED CHROME PLATED POWER WITH,RETRACTABLE OVERFENDER WITH SIDE STEP WITH (WIDE TYPE) Fr. GUARD/BULL BAR BUMPER GUARD Interior CONSOLE BOX WITH FUEL LID OPENER WITH SEAT MATERIAL FABRIC Fr. SEAT Fr. SEAT BELT 3PELRx2 POWER SEAT WITHOUT LUMBER SUPPORT WITHOUT VERTICAL SEAT ADJUSTER WITHOUT Rr. SEAT Rr. SEAT BELT 3PELRx6 HEAD REST WITH(5) SPLIT FOLDABLE SEAT WITH;3RD TRANSVERSE CENTRE ARMREST WITH ADJ. SEAT BELT ANCHOR WITH TACHOMETER WITH Fr. SPOT LAMP WITH ACCESSORY METER MULTI-INFO. TYPE DIGITAL CLOCK WITH+OUTSIDE TEMP INNER REARVIEW MIRRORS DAY/NIGHT SUN VISOR D+P VANITY MIRROR D+P W/LAMP SEATING CAPACITY 8 Electrical WIPER Fr ADJ. INT. WIPER Rr INTERMITTENT POWER WINDOW WITH POWER DOOR LOCK WITH KEYLESS ENTRY WITH WINDOW DEFOGGER WITH TIMER METER ILLUMINATION CONTROL -- RADIO AM/FM/SW ETR CASSETTE STEREO WITH,CD/MP3 CHNGR,4 SPKS POWER ANTENNA WITH AC/HEATER DUAL AUTO/WITH CRUISE CONTROL WITHOUT COOL BOX WITHOUT Others SPARE WHEEL COVER WITHOUT PINTLE HOOK WITHOUT REAR LAMP GARNISH WITH REAR LICENSE PLATE GARNISH WITHOUT FOG LAMPS WITH MUFFLER CUTTER WITH REAR PARKING SENSORS WITH FRONT CORNER SENSORS WITHOUT BLUE TOOTH TELEPHONE KIT WITH WOODGRAIN PANEL (CENTRE CLUSTER) WITH WOOD + LEATHER STEERING WHEEL WITH WOODGRAIN GEAR KNOBS WITH Есть файл с описанием различных комплектаций GX и VX. Вышлю по запросу. allege72@rambler.ru |
kostya |
1.8.2007, 13:02
Цитата(Allege) Не могу понять какой двигатель стоит - написано 2,7 VVTi? что это 2TR или 3RZ.
2TR Цитата(Allege) Вообще стоит брать или нет?
Смотря чего ты хочешь от машины? Умеренного расхода в городском режиме, тогда выбор отличный. Быстрой езды по трассе и запаса мощности при обгонах, тогда можно найти вариант и получше. |
10.8.2007, 19:33
Если хочешь обязательно взять "адаптированную" 2.7-ку, то вот тебе несколько советов, что должно быть и чего не быть у адаптированной Прадо 2.7:
14)Нет второго кондиционера для задних пассажиров 5)Нет подсветки зеркал в противосолнечеых козырьках. 6)У стеклоподъемников режим "авто" только у водителя. Костя, так получается, какую комплектацию "адаптируют"? Или все перечисленное тобой (кроме" если повезет"), должно быть? Вот вышеприведенные пункты я выделила, потому что именно они встречаются и не на "адаптированных" моделях, а просто у "пустой" с 2,7 в ОАЭ. "Схлопывание" зеркал, подсветка в козырьках, кнопки - это все привилегия "полной". Наверное упустила нить разговора, поэтому глупый вопрос получается, но кто и где "адаптирует"? Что-то меня из регистрации выкинуло. Я из семьи Колег. |
kostya |
10.8.2007, 19:42
Гость, Получается, что адаптируют самую простую комплектацию, но в этой простой комплектации довольно часто присутствует люк и принудительная задняя межколесная блокировка.
Кстати чуть не забыл у "адаптированных" там где должен быть компьютер, только часы и температтура за бортом, всего остального НЕТ. P.S. Адаптированные обозначаются как GKPEK, а арабы GKPEKV, это видно на табличке под капотом, там где ВИН. |
10.8.2007, 20:46
Цитата(kostya) Гость, Получается, что адаптируют самую простую комплектацию, но в этой простой комплектации довольно часто присутствует люк и принудительная задняя межколесная блокировка.
Кстати чуть не забыл у "адаптированных" там где должен быть компьютер, только часы и температтура за бортом, всего остального НЕТ. Костя, ты в он-лайне? Давай постучимся. Интересно со знающим поговорить, а у меня не просто спортивный интерес. Сейчас на Прадо 2,7 такой тут бум, просто все под чистую сметают, без разбора. За год отправки Прадо 2,7 различных комплектаций мне никогда не попадалась "пустая" комплектация с люком. Насчет блокировки не знаю, это уже технические вопросы, я в подробностях не сильна, но визуально, естесственно, сказать могу. Так вот: люка - никогда не было. Это вообще один из признаков хай спецификации. Схлопывание зеркал - только на полной, только передний кондиционер - только на пустой. И только на пустой - железные диски. Я почему интересуюсь то? Вот именно сейчас, из-за этого бешенного спроса на Прадо 2,7 не стесняются выдавать за "полную" даже машину с одним кондиционером. На вопрос: откуда же такая комплектация (это когда знаешь оригинальную, конечно) называют любую страну Залива за исключением Омана и ОАЭ. И вот еще случай, прямо в вчера произошел, с моим заказом. Закупаем машину Прадо, черную, 2,7. А часом раньше мной была продана Прадо 2,7, саудовской спецификации, она, действительно, беднее оманской. Уточняю у поставщика что входит в черный Прадо за проплаченную по полной цену. Объясняют что. При этом берутся в расчет только основные отличия "полной" от "базы". Т.е. диски, дерево в салоне, СД плеер, парктроники. Про задний спойлер и "слопывание" разговора не было. Но я то подрузамевала, что двойной конд., "схоп", спойлер -это должно быть в ЛЮБОЙ полной комплектации! Ладно, привозят машину, я смотрю и у меня начинает повышаться и без того высокая вокруг температура! Вот видно, что все, что установлено на этой машине не самопал, но комплектация бедная! Начинаю звонить поставщику, ругаться, деньги- то одинковые заплачены, что за предыдущую машину (соответствующую компл.), что за эту! Мне говорят, все, о чем мы с вами договаривались в этой машине есть. Про зеркала говорили? Нет. Про спойлер говорили? Нет. Ну и далее. Прошу скидку по цене, раз недокомплект. Категорический ответ "НЕТ"! А если возвращать машину будете, говорят, то сумму то мы уменьшим, это ведь вы отказываетесь. Ну представить мое состояние можно... Деньги клиента, доверие тоже... Тогда я начинаю искать на табличках, бирках ремней хотя бы дату выпуска машины. Хотелось все-таки знать, откуда такая гадость прибывает? Нигде ни даты, ни намека на арабскую вязь. Вин начинался с буквы J. Тормошу мужа, давай, говорю, проверять по вину. А, мы еще открыли капот, а там (если стоять лицом к капоту) в левом "нижнем" углу пустота! А в нормальной, 07 г. (у нас как раз стояла во дворе такая) там какое-то железо присутствует. Пробили, оказалось: машина выпуска 2006 г., и даже не для стран Залива, а просто General. Это значит, что возможно, и для стран Африки! Они туда входят и такие на рынке Эмиратов продаются. Не примите по незнанию за "адаптированную"! В комплектацию машины вошли: дерево (пластины на дверях), кожанный руль, кожанные ручки переключателей скорости и мостов, СД-плеер, "авто" стекла только со стороны водителя, двойной кондиционер с обдувом заднего салона, задние парктроники, легкосплавные диски (5 шт), АБС, стикерсы на боках, но без надписи "Прадо". Как только я позвонила и сообщила про установленный год выпуска и сказала, что докажу это документально, мне тут же было сказано, что машину заберут, пришлют другую, все, что моя душа пожелает и даже больше, за эти же деньги (которые мы заплатили) будет поменяно и установлено, только чтобы шума я не поднимала. Вот, буду завтра ждать новую машину. Во истину "жадность фраера сгубила!" А ведь я просила скидку за счет комплектности всего 100 долл, тогда может и не стала бы докапываться до истины. Она бы всплыла при растаможке и меня бы порвали на британский флаг! И имидж был бы безвозвратно погублен. Уже и забыла, к чему я это все. Но, мне кажется, подобная инфа никому не помешает. КОлег Свет. (мой компьютерный гений отключил какие функции, теперь надо регистрироваться по-новой, поэтоу и подписываюсь). |
kostya |
11.8.2007, 23:17
Кстати, сегодня мне перекуп на авторынке, с пеной у рта доказывал, что бывает версия 120-ки с 2.7 и пневмоподвеской, типа для Европы
DML |
13.8.2007, 9:23
Интересно получается, на неделе товащь попросил подобрать Прадик в Киеве, поехали по салонам - в Киеве продают Прадо 2.7 с люком, с одним кондером, складывающиеся зеркала, нет вязи на зеркалах, нет парктроника, нат авто режима на стеклоподъемниках, нет спойлера на двери - выдают такую тачку за Омановскую и просят на 500 долл меньше чем за типа "эмиратовскую" - в которй есть 2 кондера, режим авто, вязь на зеркалах, парктроник, спойлер и форкоп, но нет складывания зеркал.
Кроме этих, есть еще две комплектации: - полностью голая на стальных дисках, с черными бамперами, без противотуманок и без АБС - аналог эмиратовской (2 кондера, форкоп, парктроник, дерево руль), СД, но нет дерева на дверях, нет АБС, ручки открывания дверей в салоне просто пластик, а не хром. Хе, именно такая у меня. |
kostya |
13.8.2007, 13:54
Цитата(DML) (2 кондера, форкоп, парктроник, дерево руль), СД, но нет дерева на дверях, нет АБС, ручки открывания дверей в салоне просто пластик, а не хром. Хе, именно такая у меня.
Зачем же ты взял без АБС, или не предупредили :?: |
DML |
13.8.2007, 18:05
Цитата Зачем же ты взял без АБС, или не предупредили
Ответ 1. цена - 5 тыс долл по сравнению с такой же но с АБС, 2. На предыдущей машине несколько раз чуть не распрощался с жизнью из за АБС. Тормозной путь удлиняет не слабо!!! Так что сознательно отказался от этой примочки. |
kostya |
13.8.2007, 18:36
Цитата(DML) цена - 5 тыс долл по сравнению с такой же но с АБС.
Нифига себе, что за бред, 5килобаксов за АБС |
DML |
13.8.2007, 18:50
Цитата Нифига себе, что за бред, 5килобаксов за АБС ты че свою за 40 взял
39500$ В комплектации - 2 кондера, все стекла с авто режимом, спойлер, задний парктроник, форкоп, руль дерево с кожей, борт комп полный, насадка на глушак, противотуманки, бампера в цвет кузова (короче все тоже, что и на тачке за 45 тыс, но нет абс, нет хрома на ручках открывания дверей в салоне, нет дерева в дверях, но есть дерев вставка вокруг магнитофона и блока управления климатом и рукоядка кпп с деревянной вставкой. ) |
kostya |
13.8.2007, 19:21
DML, А фаркоп у тебя в виде крючка или в виде толстого буксировочного кольца :?:
Allege |
22.8.2007, 16:15
![]() Общительный ![]() ![]() Группа: Пользователи 4wd.ru Сообщений: 82 Регистрация: 9.8.2007 Возраст: 53 Пользователь №: 4337 |
Смотря для какой комплектации "маловато". Для Украины и Казахстана это безумно дорого. Я тоже проплатил авто, приход конец сентября.
Для максимальной GX (MP3+CD чейндж+DVD) c меня 51 тыс бакинских. |
Бродяга |
22.8.2007, 17:00
![]() Общительный ![]() ![]() Группа: Пользователи 4wd.ru Сообщений: 80 Регистрация: 21.8.2007 Возраст: 62 Из: С УРАЛА Пользователь №: 4391 |
Allege,
мой в тонировке и сигналку ставят...))) мп3+ тв+ двд+ нафигатор+кожа= 50400 убитых енотов...я доволен, в москву звонил.. если есть че в подобном комплекте дык 50900... 52000... |
kostya |
22.8.2007, 17:22
Цитата(Бродяга) kostja,
маловато будет... но поздно сегодня проплатил... в техпаспорте прописано 129 кВт( 175лс) ... врут наверное Врут. Реально (честно) 120 кВт. |
Allege |
22.8.2007, 17:59
Бродяга,
цена несомненно хороша. Для навигатора скорее всего карт не найдешь (бесполезен), кожа это +, у меня ткань и без сигналки. Но и регион СФО - может поэтому цена выше... :roll: Двигатель 2,7 VVT-i (2TR-FE), АКПП, 4WD - FULL TIME (LSD (CENTRE DIFF.), рейлинги на крыше, задний спойлер, литые диски, противотуманные фары, задние парковочные датчики, боковые зеркала - хром, темный салон (темная ткань сидений и салона), вставки под дерево в панели на дверях на руле, CD/MP3 чейнджер, телефонный комплект BLUE TOOTH, 2 кондиционера, печка и т.д. + DVD(доп.опция 15600руб)... Запаска снизу. |
Бродяга |
22.8.2007, 19:59
kostya, Allege,
ВАХ ДО ВСЕГО ПРИХОДИТЬСЯ ДОХОДИТЬ САМОМУ. оченнь рекомендую прогу вот результат расшифровки RESULTS OF VIN DECODING VIN: JTEBL29J875077747 Parameter Value 1. Mark: TOYOTA 2. Model: Land Cruiser 120 (Prado) GX 3. Model year: 2007 4. Model code: TRJ120L-GKPEKV 5. Chassis: TRJ120 6. Body type: wagon 7. Engine series: 2TR-FE 8. Engine type: petrol 9. Engine displacement: 2694cc 10. Description of engine: L4, 16V, DOHC, EFI 11. Power (DIN/JIS): 163 hp / 151 hp @ 4800 rpm 12. Torque (DIN/JIS): ... / 241 Nm @ 3800 rpm 13. Compression index: 9.5 14. Fuel rate: 12.2R (JIS, cycle 10-15) 15. Drive: 4WD 16. Gearbox: automatic 17. Steering: left-hand drive 18. Manufacturer: Toyota Motor (Japan) 19. Country: Japan 20. Market: Gulf corporation council 21. Frame №: TRJ120-5077747 Decoded by VINformer тут и моща 163 лошадки, и крутящий 241... |
Бродяга |
22.8.2007, 20:03
прога весит 3,5 метра.. но результт дает мнгновенно...
kostya |
22.8.2007, 21:04
Ну правильно 120 кВт = 163 силы, но никак не 175.
kostya |
23.8.2007, 9:52
Allege, Ну может быть если бы авто собиралось в России, а так я думаю, что 163. У меня вообще по этой проге выдало 161-163 л.с. именно через "-" .
| Текстовая версия | Сейчас: 23.4.2026, 22:25 |
